Paint thickness gauge
Just got a paint thickness gauge and am new to measuring paint. The one I have is just a cheaper one that measures all three layers. Just wondering, what's your rule of thumb when it comes to measuring paint thickness? How do you know if you can or can't wet sand/compound? Any advice is much appreciated!
Re: Paint thickness gauge
I have wet sanded a new trunk on a Nissan that I thought was safe to wet sand (120 microns) and burned through using 2000 grit sand paper. Wet sanded may cars in the past, but it only takes one strike through to make you weary.
it's impossible to know for sure. massive experience gives you an index in your head, so you end up knowing what years of what makes with what models made in what factories come with what sort of thickness...but other than that, it's so hard to know for sure.
some people say they use the door jambs as a guide for clear - the theory is that the jambs have the least amount of clear so you can loosely compare and contrast that measurement vs. your exterior panel to gauge.
i have a DFT Combo gauge and what i've found is that it's most useful to help quantify how much work you've done. you can go around on a given panel and get an idea of what the panel has...maybe compare it vs. similar panels on the car and get an idea of where it should be to start. plus that can help detect if your panel is particularly higher or lower vs. the others.
Note:
µ = microns
The following are some of the coating industries' current average
thickness-standards, that have been adopted at many OEM's paint kitchens.
______________________________________________
E-coat.............1.0-1.2 mils = 25.4µ--30.48µ
Followed by:
•Primer Surfacer...~1.2 mils = ~30.48µ
•BaseCoat........0.4-1.0 mils = 10.16µ--25.4µ
•ClearCoat........1.4-2.2 mils = 35.56µ--55.88µ
Total..................3.0-4.4 mils = 76.2µ---111.76µ
Add E-Coat.......1.0-1.2 mils = 25.4µ---30.48µ
Total Thickness..4.0-5.6 mils = 101.6µ---142.24µ
Now:
In order to stay within OEMs' paint warranty recommendations:
•CC removal: no more than: 0.3-0.5mils = 7.62µ--12.7µ
So...Using the above #s:
If the starting EPTG measurement reads: 4.0 mils/101.6µ...
Then:
At the end of all of the sanding/compounding/polishing steps, (while the vehicle's paint is under warranty), the EPTG measurement should be no less than: 3.5mils = 88.9 µ
-IMHO...
When it comes to certain "paint correction" steps:
Extreme Caution should be exercised when EPTG readings are anywhere near the low end of the spectrum!!
YMMV.
Thanks guys. What's an "E" Coat?
it's like powder coating but with paint. they charge the components so they are attracted to each other. they can help control a lot of aspects of the finish by manipulating the voltage.
Bob,
Where are those numbers from?
I have not seen it stated so definitively before
Kyle
Originally Posted by allenk4
Bob,
Kyle
My friends over at BASF and DuPont!
Food for thought.
Talk about trouble determining total paint thickness:
How many EPTGs, that can measure 3 film layers, will become anachronistic...when all of the OEMs start incorporating the primer/color-coat?!?!
How many manufacturers use the E coat?
Food for thought.
i don't think that will change anything other than the standards for what we expect to see when we measure...until it becomes common knowledge that X automaker is doing that.
if a gauge can measure three individual layers, it will then show two in your scenario. if that combo happens (don't know anything about it), then hopefully they will have gauges that can read indiv layers on AL and steel panels in the first place lol
By JohnnyRocket in forum Ask your detailing questions!
Last Post: 03-07-2018, 02:23 PM
By Hllywd in forum Hot topics & Frequently Asked Questions
Last Post: 05-10-2016, 10:32 AM
By allenk4 in forum Products Guides
Last Post: 02-29-2016, 10:54 PM
By kevin_1981 in forum Auto Detailing 101
Last Post: 07-23-2014, 05:29 PM
