Re: How To Use the Dupray Hill Injection Steam Cleaner
On Autogeek.net
Don't forget to stock up on microfiber towels. You can use any color but white shows how much dirt and grime you're pulling from the surface being cleaned. When you switch to a clean towel and no longer see dirt building up you know the area is clean and you can move on.
Arctic White Microfiber Towel - 16 x16 inches - 6 Pack
Technical information from the Autogeek Store
The Dupray Hill Injection Steam Cleaner offers the most powerful steam cleaning capabilities available in a portable commercial unit. This powerful Tecnovap machine is capable of cleaning and disinfecting faster than traditional methods can.
The Dupray Hill Injection Steam Cleaner harnesses the power of steam to clean every inch of your vehicle, both inside and out and is also capable of deep cleaning nearly any area of your home.
Pro Grade Tool
If you’ve ever used another commercial steam cleaning unit, you may have gotten the impression that these machines are beasts that are best left to professionals. Lesser consumer-grade machines take what seems like forever to heat up, use gallons upon gallons of water to run, and have only one pressure setting, making them unusable on delicate surfaces. That’s not the case with the Dupray Hill Injection Steam Cleaner.
Heats up fast, uses little water
It heats in only 7 minutes, uses very little water, and offers fully adjustable variable pressure settings. This is especially important when working on delicate surfaces where the disinfecting power of heat is more important than the actual steam. The Dupray Hill Injection Steam Cleaner includes a generous accessories kit for a multitude of cleaning projects.
Low Humidity Dry Steam
The Dupray Hill Injection Steam Cleaner offers a low-humidity dry steam system not usually available in an affordable commercial unit. Producing 62g per minute, the Hill Super Inox utilizes steam with a 5% humidity content and heats to a maximum temperature of 345° assuring a perfectly clean surface that will dry quickly, eliminating the risk of mold or mildew forming.
Disinfects and kills
The high heat disinfects—even killing bedbugs—without the use of chemicals. Since the Dupray Hill Injection Steam Cleaner uses little water, has a 3.2 quart water reservoir, and can be refilled while the machine is in use, you’ll be able to finish the job even faster!
High pressure steam
With an unmatched 121 psi of steam pressure, the Dupray Hill Injection Steam Cleaner is ideal for loosening up difficult automotive residues like brake dust, carbon, oil, salt, diesel smoke and more.
High heat rinsing
Boiling water is then injected into the steam to aid in rinsing the residues away faster than ever before!
Large capacity water tank - Rust proof stainless steel construction
Each Dupray Hill Injection Steam Cleaner features a stainless steel body and a 2.1 quart stainless steel boiler, making for a stronger, more durable machine that is easier to clean than inferior plastic models.
The TIG welded stainless steel boiler in the Hill Injection machine is designed to outperform and outlast standard aluminum or steel found in other steamers. Each machine features an electromagnetic float system within the boiler to clean scale, calcium, and mineral build up during regular operation.
Uses normal tap water
This float system allows the use of tap water without the fear of clogging the machine. In fact, the system only requires a quick 60 second drain and rinse after every 50 hours of operation. If you’re worried about expensive replacement parts, don’t! Unlike other systems that require the entire boiler to be replaced when the heating element goes out, the Dupray Hill Injection Steam Cleaner incorporates replaceable heating elements that save you time and money!
Lots of optional accessories to get into and clean just about anything
The Dupray Hill Injection Steam Cleaner includes 24 Tecnovap accessories designed to withstand the high temperatures that the steamer produces, while offering an option for nearly every cleaning need. With the Dupray Hill Injection Steam Cleaner and all of its accessories you will be able to clean your vehicle’s paint, upholstery, rims, engine bay, floor mats, carpeting and more. When you’re done detailing your vehicle, take the Dupray Hill Injection Steam Cleaner inside the house to clean grout, flooring, walls, upholstery, and even kill bedbugs!
Product Features:
- Durable stainless steel body.
- Easy-to-use variable pressure controls at your fingertips.
- Maximum 345°F Steam temperature with digital gauge.
- 121 psi of steam pressure.
- Self-cleaning fully stainless steel boiler with lifetime warranty.
- Commercial quality components.
- Heavy duty accessories.
- 3 year warranty on parts.
I love my steamer but it's no where near this fancy. Did you really need to use the phrase "body oils"? Ewwwww!
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by TundraPower
This model is definitely fancy and the end result of all the fanciness is you do better work faster.
Hey... interior cleaning includes removing all kinds of icky things...
At least with steam you're also killing all the microscopic critters at the same time.
I have the same machine and can't imagine living without it. I've removed years of encrusted salt stains with the injection feature. What would have taken hours and lots of elbow grease takes minute. As you said though the best feature is the continuous fill. I've never been able to do a car without re-filling at least twice and sometimes up to 4 times. They aren't cheap but time is money.
What`s the price for this type of machine Mike?
I use steam in all my interior details and for more or even deeper cleaning I follow with the Portable extractor. This way I know for sure I`m not just cleaning And desinfecting, I`m Pulling everything Out!!
You have it in stock Mike?
Last Post: 07-12-2019, 10:42 AM
By Maestro Sam in forum Auto Detailing 101
Last Post: 05-21-2017, 08:57 PM
By Eric M. in forum Auto Detailing Tools and Accessories
Last Post: 08-13-2013, 02:42 PM
By Eric M. in forum Auto Detailing 101
Last Post: 07-26-2013, 12:02 PM
By precisionautosalon in forum Auto Detailing Tools and Accessories
Last Post: 07-03-2012, 06:46 PM
26 | 27 | 28 | 29 | 30 | 31 |
