Breaking the Collinite Myth: 915
Originally Posted by KillaCam
915 isn't bad if machine applied, but applying by hand I have difficulties with it. It's hard to get an even thin coat without a machine and it will get hard quick.
Really? Maybe the product is slightly different I'm using. The 915 I have spreads velvety smooth. Maybe they have tweaked it.
Re: Breaking the Collinite Myth: 915
The pic of the rear fender flare says it all for me.
Gonna lay it down on the Regal sometime soon... maybe even Ol' Blue.
I need to stop ordering stuff and NOT using it.
VT
Originally Posted by glen e
WoW! I have had the 915 for a couple months now and haven't even used it because I was waiting to get a couple 3" pads to apply with DA because off the talk from some here.
Last night I decided to try by hand on my just washed DD, a dark grey Corolla. I used BnS red foam applicator. The ease of application HONESTLY was the easiest to spread out, took so little I didn't even make a dent. I did the entire car then dressed my tires. I then wiped off all panels with no effort at all, it just cleaned right off. It was late at night and the temp must have been around 50° .
I had used Megs gold paste before, but that only happened once because I hated the process by hand and to top that it was dusty on removal. Now this morning I noticed that glow from 915, it added depth and just looks like it has a layer of glass, Megs just doesn't compare.
Only complaint I have is not jumping on 915 sooner!
How exactly do you get a pad into the small cicumference opening of the can of #915? I'm sorry you've had issues when applying by hand but its just never been a problem for me. Could weather conditions be an issue, maybe?
2022 Elantra N Cyber Gray
I may have over applied because the vehicle I applied it to could've benefitted from a cleaner wax after I clayed it. It was really sticky applying it and the foam applicator wanted to fold up a lot.
When using a machine, I get a butter knife a scoop a small amount on the pad and wipe it on like you would butter toast.
Originally Posted by MarkD51
The one quality worth mentioning that I have found with any of the Collinite Paste Waxes, is that if you are not a professional, and not applying such waxes on a regular basis on a multitude of vehicles, you will have a can of Collinite for a very long long time.
This is true for #845 as well, I've had my bottle for about 4 years now.
Do you heat up the container a bit Killa, just curious? I think your onto something about the why its a little harder to remove for you, me on the other hand, well, I layer a lot, which is probably why I have never had an issue applying/removing anything, LOL!
Yet another use for the GG 3" RO!
That's a HT 3" pad??? Mine look different. I have that pad in both heights. It looks like your edges are beveled - but mine are 90 degrees.
By Stauffer Garage in forum How to Videos
Last Post: 09-21-2019, 06:38 PM
By AustrianOak82 in forum Ask your detailing questions!
Last Post: 10-02-2014, 01:51 PM
By davidc in forum Products Guides
Last Post: 09-11-2014, 10:27 AM
By trhland in forum Auto Detailing 101
Last Post: 04-21-2007, 01:14 PM
By dennish in forum Auto Detailing 101
Last Post: 06-14-2006, 03:38 PM
