^^ exactly. D301 I a cleaner wax and it was designed to be part of the DAMF 2 step for production detailing. Now that D302 out, it allows someone to use a different LSP. It'd common to follow up D300 with M205 and foam or UP an foam to remove DA haze and refine the finish.
So in your opinion D302, Ultimate polish and M205 will do a better job than D301 with white or black foam pad as a final polishing step? I used D301 with MF finishing disc after D300 with cutting disc but this combo left some haze on jet black BMW. I couldn't see a difference between UP and D301 with soft foam pad. But of course it feels more professional to use M205 followed by UW or M26. That's why I'm about to order M205 and M26. Honestly It's unecessery but I have to try.
Yes it would. The difference between M205 and UP is the M205 offers better correction while UP offers more polishing oils. M205 is more versatile. I have not used D302 yet but it's supposed to remove DA haze while staying with the MF system.
Today I tried UP with soft polishing pad and UW by hand. Left UW 20 min before I buffed it off, this together with the temperature being much cooler today helped with buffing the UW off without streaking.
Hi guys, need your oppinion, which one will get best result to get shiny white car?
1. D300 w/ mfcutting pad + D301 w/ mf finishing pad
Or
2. Ultimate compound w/ cutting foam pad + ultimate polish w/polishing foam pad + ultimate wax w/ finishing foam pad
I only have that. Should I add more items too get shiny white car?
It seems that d302 not ready in my country, Indonesia.
Sent from my GT-N7100 using Tapatalk
Re: New Meguiar's DA Microfiber Correction System Video
It depends on how much correction you really need. Try a test spot with UP. If you need more correction then try UC and if you need more correction then go with D300+MF cutting pad.
And for the best finishing result? Ultimate liquid wax or d301?
Actualy i want to make my 2,5 years white car shine like new again. That white color is not bright anymore
The easy way is going to autodetailing store, but i wanna try to do it by my self
That's up to you on what you're looking for. D301 is a cleaner wax and ultimate wax is a sealant. Ultimate wax offers longer protection of the 2. If it was me I would follow up polishing with ultimate wax.
Thank you The Guz. I'll try it.
Or
This question cannot be accurately answered via the Forum
ONLY a Test Spot will reveal the combination of: pad, compound, polish, machine speed, downward pressure, number of passes.
By Meghan in forum How to Videos
Last Post: 06-06-2021, 12:00 AM
Last Post: 12-17-2013, 11:48 PM
By Mister B in forum Product Reviews
Last Post: 10-01-2011, 04:29 PM
