Surgical Precision Buffing Tools
Here's a few tools for surgical precision buffing. I define surgical precision buffing as a way of using smaller pads, smaller backing plates, extensions on your rotary buffer and a lightweight, compact rotary buffer.
Using these smaller pads on a easy to hold and maneuver compact rotary buffer makes buffing out tight areas, thin panels, intricate designs, motorcycles, miscellaneous painted components like rear view mirrors, spoilers, windshield frames, a-pillars, etc. a lot easier and safer.
Going small...
Flexible 3" backing plate
Short pile length PFW pads...
Rotary Buffer Extensions
Cyclo wool pads
These are made for the Cyclo Polisher but I've used them successfully on rotary buffers. You can also use the Cyclo foam pads on rotary buffers as well as other tools.
4" Lake Country Wool Cutting Pad
The back of this style has a flexible plastic liner to prevent the fibers for the pad from bending back potentially allowing the backing plate to buff into the paint.
See how it fits around the outer edge of the backing plate...
Purple Foamed Wool Pads
Below is the new thin PFW on top of the original PFW which as you can see, the new pads is very thin, this means it should work exceedingly well on DA Polishers and the original version is very thick.
And sometimes I like to use the extensions with larger backing plates and pads too...
Extensions for Dual Action Polishers?
There are no extensions for other tools, thought I would add this because the question gets asked all the time. You don't want to try to use an extension on any type of dual action polisher, it's not going to work.
The above isn't a complete collection of everything we have at Autogeek for surgical precision buffing but you get the idea...
As I can, I'll take more pictures of more cool tools and add them to this thread...
Re: Surgical Precision Buffing Tools
Man I need a PE14.
Thanks for putting this together Mike.
No Go
I get asked all the time about an "extension" for a DA Polisher. The answer is "no".
I actually mention this in the above article but if you simply scan the article you can miss it so here it is again...
There are no extension for other tools, thought I would add this because the question gets asked all the time. You don't want to try to use an extension on any type of dual action polisher, it's not going to work.
Because a dual action polisher oscillates, extending a backing plate and pad further away from the spindle is going to make the pad wobble and this will make the tool wobble and you won't be able to do anything when the tool is wobbling out of control.
Using an extension on a dual action polisher would also tend to wear out the bearings that support the spindle faster.
The extension is for use with rotary buffers only. The good news is it works GREAT with rotary buffers to get your pad away from the body of the tool so you can see more clearly what your pad is doing in intricate and tight areas.
No Go
Exactly the information I was after. I'm converting my 7424 to 3" pads and gave an extension some thought, thought of the possible end result, then thought, "I'll bet Mike wrote about this years ago." Thanks!
Last Post: 05-07-2014, 08:58 AM
By Tato in forum Auto Detailing Tools and Accessories
Last Post: 03-24-2014, 04:06 PM
Last Post: 12-24-2013, 09:24 AM
Last Post: 10-26-2013, 08:48 PM
Last Post: 03-20-2009, 06:40 AM
