Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
    Super Member TrKent's Avatar
    Apr 2012
    Dulles, VA
    517
    Re: How To Use The Flex 3401
    Mike, how is it that the Flex is able to work in larger sections? I thought that section size was limited by the product and pad not by the polisher.
    Quote Originally Posted by TrKent View Post
    Amount of product and pad are factors but not the only factors. I used the "ample" amount of product and worked hard. It would be easier to have tackled a smaller section but I wanted to show "what could be done" plus "what I could do", if you're new to machine polishing you might want to tackle smaller sections.
  3. #13
    Apr 2012
    Dulles, VA
    517
    This is good to know. I've been using the 3401 for a little over a year now and am about to detail a F350 with a long bed. I'll be testing out this larger section size. This job should go by a little faster now
    Owner of Dream Detail LLC
  4. #14
    How did the F350 turn out?
  5. #15
    Also just to note, when I worked this section, approximately 1/4 of this large, full size Chevy with a full size hood, I stood at the passenger side fender as this let me work the entire length of the hood from one standing position in a non-stop, overlapping motion with the polisher.
    Here I've turned the polisher on and spread my working product evenly over the entire surface I'm going to work.
    I'm not saying tackling a huge section like this at one time is easy or the best approach for all detailing projects but for me and this project I was able to knock out the hood doing sections this large.
  6. #16
    Apr 2012
    Dulles, VA
    517
    After about 50 hours... it came out pretty nice, I'll try to repost the video I had on youtube of it... I don't have many after pictures, but there was quite a bit of after-video.
  7. #17
    Apr 2012
    Dulles, VA
    517
    Speaking of working large sections, check out 1:48 on this video:
    Dream Detail - Lexus SC430 - YouTube
  8. #18
    Nice video and great demonstration on buffing out large sections.
  9. #19
    Apr 2012
    Dulles, VA
    517
    Thanks Mike!!
  10. #20
    Super Member Toxix's Avatar
    Aug 2012
    Toronto, Ontario, Canada
    218
    I see someone else asked the question but didn't get an answer, hopefully someone can update.
    I've been using a 7424XP with 5.5" Pads.
    Had a bunch of 6.5" pads which were overpowering the PC.
    Obviously this isn't the case, what pad sizes are people using now?
  1. FLEX 3401 on its way out
    By IID in forum Flex Polishers
    Last Post: 11-11-2017, 04:35 AM
  2. Flex 3401 or FLEX XFE7-15
    By DETAILROOKIE in forum Auto Detailing 101
    Last Post: 05-25-2017, 10:49 AM
  3. Replies: 9
    Last Post: 10-17-2013, 05:20 AM
  4. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  5. FLEX 3401 HD, what ya think?
    By Grifftech in forum Auto Detailing 101
    Last Post: 08-29-2012, 02:44 PM
