McKee's 37 Product Support
Re: How To: Detail Your Engine Like a Professional
Originally Posted by Dynamic_Detailing
Great idea, and awesome write-up! Thanks as always Nick
My pleasure.
I have to admit this is a good write up I haven't had the pleasure of reading before. Thank you .... very nice Nick!!!!
Great write up Nick,
So it would seem most of the newer cars have plastic covering which makes cleaning a breeze. but on older cars everything is exposed. Is there anything down low in the engine bay that could be effected by water as it going down where one can not reach?
And how do you guys who detail go about such things if asked by a customer. Are some cars just to iffy where you would want to stay away from? If a car is old it may have cracks or leaks you can not see, if something gets wet your to blame. Is it possible to use an engine bay cleaner than maybe just a towel to wipe, than a QD to wipe down followed by a trim spray?
The alternator and intake are easy, the wires are what freaks me out.
You are really a pro. Thanks for the write up because it was really informative and useful. I don't know what to say because you nailed it all right.
The connectors on cars have been sealed for ages; even my el-cheapo 1983 Toyota had sealed connectors. That was 30 years ago.
Pull a connector apart and you'll see a rubber seal/o-ring within the housing. As for the wiring entering the back of the connector, those are sealed as well...if it is a quality car.
Am I the only one that caught the fact that there is no information included on how the covered wiring connectors, alternator, etc... were cleaned without using water??? Any tips on that? I know how I do it, but I'm always open to learning better ways.
Input?
See one post above your post...^
Unless you have an old car where they didn't use quality water proof connectors, why would you cover them.
My old 1983 Toyota Corolla even had sealed connectors and anything these days, every connector is sealed with O-rings and rubber seals where the wire enters the connector. If they aren't...cheap car.
Input?
Sorry to resurrect an old thread
Electrical connectors, really the plastic part thereof can be cleaned with a cable cleaner. This type of cleaner has a very high dielectric strength that won't cause a short circuit or track, and removes grease and contaminants at the same time. Something like Pow-R-Wash breaks down above 62kV, so 12 V systems are fine
Cleaning the metal parts of the connector , such as CRC 32 is OK, but on some plastics, CRC is too aggressive, causes the plastics to go sticky.
Application of the cable cleaner is spray on to a (tooth) brush, rub in then wipe dry with a cotton rag. It doesn't matter if all the chemical remains in the smaller cavities, it won't cause a short circuit.
ive been wanting to do mine for a while now but keep putting it off. i just dont want to have any problems afterward. i hope saran wrap and tinfoil is actually good enough to cover the appropriate components. watched a video online last week. this guy claiming how easy it was and you can wet this and wet that. then he goes to start it and it making noises and had blown sparkplugs.
im going to be using mckees cleanse all anyway
Last Post: 12-21-2019, 11:37 AM
By UncleDavy in forum How to make money detailing cars
Last Post: 05-10-2018, 07:57 PM
By Eldorado2k in forum Product Reviews
Last Post: 01-01-2017, 02:39 PM
By nodule in forum Auto Detailing 101
Last Post: 10-11-2013, 12:51 PM
By crober53 in forum How to make money detailing cars
Last Post: 05-05-2013, 07:37 AM
