Re: How To: Detail Your Engine Like a Professional
Just curious how often do you guys wash your cars at work?
I would be "testing products" all the time
Mark
Go Orange!
Seasonal Depression Disease
"The removal of 1000 swirls starts with a single compound !"
I have a 2012 Chevrolet cruze and im in need to detailmy engine. Ive considered all the points nick pointed out for components to cover, but what I was wondering if anyone has the same car I do and has done this task already. I know cleaning an engine is safe as long as you do it right. Just not sure about doing it on my cruze. Im afraid I wont cover up everything I need to and something gets wet that isn't suppose to. The engine has a light to moderate layer of road dust and I hate looking at it all the time. So any ideas and suggestions would be much appreciated. Thanks in advance.
Detailed write up!!! As a 12 volt tech tho I would NEVER recommend cover an alternator with aluminum foil! Its very possible the cover over the battery wire is gone or never had one to begin with and would great a short.
Lot´s of info!!! great finish by the way. like I do High Pressure washing jobs also. I have my Portable Hotsy Hot watter P.W
I do a quick blow with the Handblower, the the foil, Pre-spray with my degreaser of choice using my engine degreaser gun at 100psi
Do a nice pass or two. then work with my Hotsy, on Steam mode to get all that mess out.
Final rinse with low pressure water. Blow the excess water. And give the final touch. with my Air compressor at 45psi, my detailers paint gun & my dressing of choice!!
Soo far no problems at all!!!
Not sure if its already been mentioned, theirs a ton of good information here. If I need to cover up certain components I have found that a shower cap works really good and you can reuse it unlike alu foil or saran wrap. Also you should be careful when applying dressings under the hood to avoid the exhaust manifold. If you get dressing on the manifold or anything else that gets really hot it will create smoke. If it puts off enough smoke while the engine is running it can throw a trouble code on the engine.
Great , needed a thread like this for my engine bay detailing ! Thanx for posting .
Thank you for the write up.
Costco has aluminum pop up sheets (like a Kleenix box) so I was going to cover everything with plastic wrap and secure it with pieces of foil.
I like your masking tape idea better.
I am a Megs loyalist. But your writeup deserves giving the Detailer line a "thank you" shot.
How does the DC trim spray compare to adams in and out spray. Just curious because I have in and out already
Sent from my SPH-L710 using AG Online
Last Post: 12-21-2019, 11:37 AM
By UncleDavy in forum How to make money detailing cars
Last Post: 05-10-2018, 07:57 PM
By Eldorado2k in forum Product Reviews
Last Post: 01-01-2017, 02:39 PM
By nodule in forum Auto Detailing 101
Last Post: 10-11-2013, 12:51 PM
By crober53 in forum How to make money detailing cars
Last Post: 05-05-2013, 07:37 AM
