Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Newbie Member ws6driver's Avatar
    Apr 2012
    Mohawk tn
    What are these scratches
    I have a porter cable
    7424xp with
    white, grey, blue ccs pads.
    xmt 1-4 swirl removers
    Meguires ultimate polish
    I used the white pad with xmt ultra fine swirl remover. Is this normal?
    Apr 2012
    Mohawk tn
    Re: What are these scratches
    7424xp with
    I used the white pad with xmt ultra fine swirl remover. and meguires ultra polish on the blue pad. Is this normal?
    Attached Thumbnails Attached Thumbnails What are these scratches-2012-05-06-11-15-08-jpg
    Aug 2010
    New Jersey
    15,167
    So what are you saying, you had those swirls before, and were unable to take them out, or you didn't have them before, and you have them after polishing?
    Super Member TimmyG's Avatar
    Dec 2011
    Glen Ellyn - IL
    905
    This.
    If that didn't compound out with the UC, you may need a little more aggressive combo.
    2012 Chevrolet Corvette Z06 - Torch Red
    Apr 2012
    Mohawk tn
    To answer your question i had fine swirls and i thought i could polish them out. I guess what i am asking is. Do i have the correct pads for the job? Did i use the correct combination. I am assuming i did not because of the end result.
    Aug 2010
    New Jersey
    15,167
    Which did you use first, the UP or the XMT 1? I'm not that familiar with the XMT products, but from the description, I would have used the UP first on a white pad, and then followed with the XMT 1 on the blue (or a white). Really I don't think you should need both.
    As Timmy said perhaps you had deeper swirls that you partially removed (because your picture doesn't look that bad), and you need to have another go, or use something a little more aggressive and then dial back to one of the products you already used to finish up.
    Where are you located?
    Apr 2012
    Mohawk tn
    I used the XMT 1 on the white pad and followed it up with UP on blue pad. This looks like surface scratches and if XMT 1 could have gotten them out i really dont know what i am doing..... I live in East TN. Maybe i am rushing it but i just dont have the pad and swirl combo down yet.
    Dec 2011
    Glen Ellyn - IL
    905
    Quote Originally Posted by ws6driver View Post
    I am also not very familiar with the XMT lineup but it looks like you achieved some paint correction with your previous attempt but didn't get the results you were looking for. I'd do another test spot starting with a white pad and XMT1 (I think that is the lowest cut, right?) then start working your way up if you're not getting the correction you want.
    Nice WS6! I've got one myself!
    Apr 2012
    Mohawk tn
    Quote Originally Posted by TimmyG View Post
    I am also not very familiar with the XMT lineup but it sounds like you used the incorrect pad with the Ultimate Compound. I would have started with the UC+white pad on my test spot, then moved up to an orange pad if I wasn't getting the correction I was aiming for.
    the answer maybe be i do not have the correct pads. I have white, black and blue ones. I cant test all the products out because i dont have enough pads to determine what will work on my test spots. So that is my issue? Thank you for the compliment it is actually a 2000 Trans am. With a WSQ hood.
  10. #10
    Dec 2011
    Glen Ellyn - IL
    905
    I have zero experience with the CCS pads unfortunately. I will say, I own a bunch of LC 5.5" Flat pads that always do well on my WS6. I also use some 3" and 4" LC HT pads for the many curves on the car. Comes out fantastic everytime!
    Nice car!
  1. Video: Rotary Buffer - Removing sanding scratches - Full Headlight Correction - Remove Hologram Scratches
    Last Post: 02-03-2019, 12:30 AM
  2. How to remove scratches in glass - Wiper Scratches from Beach Sand
    Last Post: 04-11-2014, 05:02 PM
  3. a few scratches
    By Dan_335i in forum Wet-Sanding, Cutting & Buffing
    Last Post: 02-07-2014, 07:32 AM
  4. The first of two scratches I would like to fix
    By parttimer in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-31-2013, 01:53 PM
  5. Replies: 9
    Last Post: 01-29-2013, 06:37 AM
