Video: How to use the Z-020 Tornador Black Car Cleaning Gun
Turbo-charged Tornador for faster, more powerful cleaning!
The Z-020 Tornador Black has newly developed rotational technology inside the funnel to provide faster, more powerful cleaning compared to the Tornador Classic. Professional detailers will love the speed and effectiveness of the Tornador Black. The new design reduces wear and ensures a longer life and superior performance.
The Z-020 Tornador Black produces enormous power with a very small air compressor. All you need is a compressor with a discharge rate of at least 270 l per minute (9.55 cfm). This can be achieved using compressors with a reservoir of as little as 50 l capacity. Mobile detailers can now use the Tornador Black with a smaller, portable air compressor.
The Z-020 Tornador Black is less noisy, too. The designers increased power but reduced air consumption and noise. Plus, the Tornador Black d is equipped with sealed ball bearings inside the rotation set. Wear is minimized because the rotation set no longer comes into contact with the cone. This improvement makes the Tornador Black better suited for long term, frequent use, as in a professional detailing capacity.
Tornador Black features:
- Double the power of the Tornador Classic
- Low wear and maintenance
- Lower air consumption
- Suitable for 240V compressors
- Lower noise emissions
The Tornador Black Z-020 can be used for all the same applications as the Tornador Classic, but the Black is more effective on persistent spots, like chewing gum. The cone-shaped nozzle and oscillating tip create a tornado cleaning action that cleans hard and soft surfaces like nothing you’ve seen before. Dirt and grime are immediately released from fabrics, carpet, and solid surfaces.
The Tornador Black Car Cleaning Gun releases a fine mist of cleaning solution that does not over saturate surfaces. You’ll see the liquid turning dirty as grime is released from the surface. Wipe with a microfiber towel. Then turn the dial to shut off the water and use the compressed air to dry the cleaned area. It’s that simple.
Use the Tornador Black Z-020 on the dashboard, door panels, steering wheel, fabric upholstery, carpet, floor mats, and between seats. It cleans in tough-to-reach places between seats and in seams. Because it releases so little liquid, surfaces dry quickly.
The Tornador Black cleans,
- Air vents
- Headliners
- Wheels
- Carpets
On the exterior, use the Z-020 Tornador Black to clean fabric convertible tops, body seams, wheels, and emblems. There’s no need to scrub. The Tornador does the hard work for you.
The Z-020 Tornador Black has an air regular to allow you to change the working pressure directly on the tool and also to dose the capacity of chemicals accurately. What this means is that you can use more pressure and cleaning fluid on tough spots.
To clean any surface, dilute the desired cleaner according to label’s directions. Turn the liquid valve straight up and use an overlapping motion as you pass the Tornador Car Cleaning Gun over the surface. If necessary, allow the cleaning liquid to dwell for 10-15 seconds. Use a microfiber towel to absorb excess liquid. Then turn the liquid valve off and use the compressed air to dry the cleaned area.
The Tornador Black Car Cleaning Gun is not a foam gun. It is a patented cleaning gun designed to remove soil with a unique cyclonic cleaning action. There's nothing else like it!
On Autogeek.net
Re: Video: How to use the Z-020 Tornador Black Car Cleaning Gun
The video is demonstrating Tarminator . . . But thanks anyway!
Rule 62: Don't take yourself to d*mn seriously
Cincinnati, OH
Shawn
Lol yea I was wondering when the tornador was going to show up
Get yourself a cup of coffee, Mike! You're working too hard again!
2012 Chevrolet Corvette Z06 - Torch Red
when did they do a redesign and why does it look like a can of tarminator?
I just got my tornador black today...any suggestions on a good portable air compressor that wont break my wallet?
Originally Posted by storm100
Someone's tired.
Originally Posted by Bamaboy007
wake up Mike
Fixed
I was typing like a speed demon yesterday working on a hot project with a deadline, besides the hot project I was multi-tasking with projects like editing YouTube videos.
I fixed the link and what happens sometimes is when you highlight a line of text and then right click and select copy, "you" did everything right but the computer memory still has the last line of copy you selected stored in memory and thus the wrong text is pasted.
Normally I seasoned enough to double check my work for simple things like this but again I was speed typing all day yesterday and today...
Luckily my mistake to post ration is very low and I always appreciate it when people have the courtesy to PM me something like this instead of post about it...
There was a thread about this lately but I'm not sure where it is... maybe do a little searching using the words
air compressor
Advanced Search for the AGO Forum
I rarely ask someone to search an when I do I try to give them the link to the Advanced Search Option to make it easy on them... on most forums someone will just post use the search button...
By Willowdale in forum Auto Detailing Tools and Accessories
Last Post: 09-08-2019, 08:53 PM
Last Post: 06-15-2019, 02:42 PM
By CarbonDetailing in forum Auto Detailing 101
Last Post: 02-08-2018, 12:19 PM
By Mantilgh in forum Hot topics & Frequently Asked Questions
Last Post: 02-13-2016, 04:31 PM
By Meghan in forum How to Videos
Last Post: 08-21-2009, 12:47 PM
