1969 AMX Wetsanding Videos - Nebraska Help in the Heartland Project
1969 AMX - Wetsanded, Cut and Polished by Team Autogeek
[/center]
Here are all the videos shot from when Yancy and I were in Lincoln, Nebraska for the 1969 AMX Wetsanding, cutting and buffing project called, "Helping in the Heartland".
Gets some popcorn and a cold drink as these are a lot of fun to watch as well as educational...
1969 AMX - Wetsanding How To Video - Part 1 - 30 Minutes
Part 1: Summary
Wes introduces the story behind the AMC AMX and then shares the story behind the LS1 engine going into it. Then I introduce Ben VanEperen, the painter who we refer to as Ben #1.
Ben shares the process he used to paint the AMX. Next I introduce Ben #2 aka Wors on our forum. Then I introduce Paul aka Sailfish on our forum, Paul is a professional marine craft detailer. Next I introduce Bob Eilchelburg, the Presideint of Flex Tools North America.
After the introduction we do a "Test Spot" on the hood to dial-in and prove our sanding and buffing process to make sure it works and we're not going to run into any problems. This includes,
- Hand sanding with #1000 3M Wet/Dry sandpaper - D.O.I. is explained after sanding with #1000
- Hand sanding with #1500 3M Wet/Dry sandpaper
- Machine sanding with 3M Trizact #3000 - This is called dampsanding.
- Machine sanding with 3M Trizact #5000
- Machine compound with Menzerna FG 400 with a Lake Country Wool Cutting Pad on a Flex PE14 Rotary Buffer
- Machine polishing with the Flex 3401 with a Lake Country Hybrid Polising Pad and Menzerna SI 1500
- Machine polishing with the Flex 3401 with a Lake Country Hybrid Finishing Pad with Menzerna SF 4000
After all of the above steps the crew inspects the results.
1969 AMX - Wetsanding How To Video - Part 2 - 15 minutes
1969 AMX - Wetsanding How To Video - Part 3 - 11 minutes
1969 AMX - Wetsanding How To Video - Part 4 - 11 minutes
1969 AMX - Wetsanding How To Video - Part 5 - 10 minutes
1969 AMX - Wetsanding How To Video - Part 6 - 11 minutes
Part 6: How to Wetsand, Cut & Buff Custom Paint - YouTube
1969 AMX - Wetsanding How To Video - Part 7 - 9 minutes
Nice work as is the norm for Yancy our videographer...
Re: 1969 AMX Wetsanding Videos - Nebraska Help in the Heartland Project
I watched as the videos were live, it looked like a great time. Being a paint guy myself I understand the pride taken when you finish a job. I know exactly how Ben#1 must have felt when he heard someone else was going to "finish" his paint job. But after being on the forums for the short time I have been has made me realize that if anyone were gonna come help, I would want Mike and his crew. You guys do amazing work, and I have learned even more than I thought was possible from an online forum.
Thanks again, and Great Work!
Yeah Ben #1 was a little hesitant and rightly so... he put a lot of time and work into getting the body panels and body shell perfect before spraying the paint and the last thing he wanted to do was see a mistake happen. The good news is never once did anyone make a mistake but that is in part because he did such a great job spraying plenty of clear.
Ben will be joining the forum so we can all look forward to having another professional painter onboard to ask answer painting questions.
Thanks for the kind words Ken. The key to doing any project like this all starts with the painter as you well know. Our job was to build on the platform he provided and to work carefully all the way through each of the steps.
We did all the work in 2 full days and a little bit of follow-up polishing on Sunday morning before we had to leave for our plane flight and while we worked hard we never rushed.
SIMPLY WOW!!!!! I never knew you took these pics......
Proheader
Mike and the crew ! Fantastic job and for a great cause. You guys really put your heart in this and it shows. You all should be proud of yourselves and the outcome was outstanding. Yancy great video/photo work, top notch...
Originally Posted by RedXray
Mike did you get a shot of the AMX's door tag with the car build sequence numbers?
If so post it up so us AMC guys can decipher the numbers. This tag gives the Paint, Trim, Body etc. The body numbers tell which plant the car was built. Kenosha-Milwaukee (east or west plant) the Kenosha Lake Front plant or the Canadian plant and the date it rolled off the assembly line.
I'll get one of the guys back at the shop to take a picture and post it...
They are busy assembling the car each day now...
Simply speechless!
Mike, any idea how much clear was laid down.
There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
Last Post: 07-12-2019, 03:11 PM
Last Post: 06-12-2013, 01:28 PM
Last Post: 02-13-2013, 08:15 AM
Last Post: 02-06-2013, 05:05 PM
Last Post: 12-13-2012, 12:36 PM
