Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 51
  1. #21
    opie_7afe
    Re: How-To: Make Your Own Rotary Backing Plate Extension!
    chinese bolt? for hardware i only buy made in usa sir.i dunno why you guys are putting my idea down so much saying it will fail, its not like its holding up 1000 pounds of cement or something its for a buffer one made out of gold would probably work just as good.is it because its not bought and its made? what is it??? if your just going to say its going to break and post negativity then please dont post. steel has a fairly high tensile strength i doubt it will break. as i said each their own you dont need to make it but you guys dont need to say it will break because if you had any mechanical ability you would know the limitations of a 5/8th inch bolt, smaller bolts hold together engines for crying out loud.
  2. #22
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Quote Originally Posted by opie_7afe View Post
    To be honest with you, I wouldn't even trust a bolt that was made here in the U.S.
  3. #23
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Don't take it so personal. Your idea seems like a good one, that is as long as it doesn't go snap, crackle, BOOM!
    This is a discussion forum, no?
  4. #24
    opie_7afe
    yes but everyone seems to say "it will break" without providing any knowledge of the true concerns of how and/or why it would break, you just say " it will break" and thats it, there is probably more of a chance my rotary will break before the extension will......anything can break but something like this breaking or "blowing up due to centrifugal force" is a crock to say the least....it seems like if its not bought from AG your in the wrong for posting about it and its a crap product that will fail....i really am tired of it, just because im young don't mean i'm an idiot. and to further prove my bolt will not snap is this link showing bolt strengths in all regions i doubt even if i used a grade 2 bolt it would snap from polishing paint....Bolt strengths
  5. #25
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    If you are not able to handle some honest friendly constructive criticism then perhaps go don't post or try the Barney forum.
    Jim
  6. #26
    Jun 2011
    Northern, VA
    1,917
    Quote Originally Posted by Dr Oldz View Post
  7. #27
    Super Member 2old2change's Avatar
    Jan 2007
    Indianapolis Indiana
    1,269
    I come from a generation where things were made out of necessity and not purchased at the local box store. You are not the only one to make this style of extension for a rotary. One member over on DB makes these and sells them on the forum. I like your idea of drilling and pinning them as a saftey feature. I've seen others welded or loc tite used . I would not be afraid to trust the extension that you have made and see no reason it would self destruct any more then a store bought unit. Just remember this is a discussion forum and everone is entitled to their own opinion. Peace.
  8. #28
    Super Member TS656577's Avatar
    Nov 2008
    South Central, Pennsylvania
    754
    Matt, it's not a bad idea. I would check out this link since it includes the shear strength of the bolts which for this case would be the big issue. For those that aren't sure what shear strength is, think of it like this: Ever break a bolt that is stuck (say on a car) and by twisting the head, you get the bolt to twist off? I guess that's the best way to put it. Anyway, the bolts are going to experience a lot more shear. however, because the rotary head is spinning at the same rate as extension, and the pad is spinning as well, I don't see why a grade 8 bolt would have issues. If you're holding the pad from moving, then i could see an issue. Anyway this is link. This is for a grade 2 bolt remind you Bolt strengths
    Trent
    PRD
  9. #29
    opie_7afe
    i dont see how your comments were constructive, but hey if you think they are then great....im not going to banter back and forth with you older guys because you are set in your ways ect....its ok though its just text and dont bother me one bit lol
  10. #30
    Jun 2011
    Northern, VA
    1,917
    Damn those old guys with their common sense!!
    Seriously, no one has brought age into the argument except you. Obviously you are sensitive about it. No one is saying you are a dumb kid. You posted an idea on a public forum and you are getting feedback, that's how it works.
    PS to the other poster, I sold some on DB, but they were machined out of solid metal, not threaded together.
  1. Video: Mark your backing plate to make it easy to see pad rotation
    Last Post: 08-13-2019, 10:11 AM
  2. Backing Plate Extension for use with Rotary Buffer
    Last Post: 01-08-2014, 01:03 PM
  3. da backing plate on a rotary
    By c5errr in forum Rotary Buffers
    Last Post: 07-11-2012, 09:56 AM
  4. Replies: 8
    Last Post: 10-25-2011, 07:47 PM
  5. Backing Plate on Rotary
    By aflyvietguy in forum Auto Detailing Tools and Accessories
    Last Post: 08-04-2008, 02:28 PM
