Re: Optimum Opti-Coat 2.0 - Permanent Paint Protection Made Easy
Originally Posted by Nick@Autogeek
I did in fact transfer it back to the syringe following a recommendation from Chris@Optimum.
For the record, I used approximately 5cc for the Camry.
Great tip, thanks for sharing!
You are welcome. I feel like people are scared to try the product but they should not be. if you are timid you could always prep one or two small panels and do just just them to get the hang of it. also saw the other tips that have been given and after reading this post our members should be prepared to apply the new coating.
Optimum Guru
Chris, after an application of Opti Coat is there a measurable difference between just the factory clear and Opti Coat with a paint gauge?
Optimum Guru
Yes, while normal LSP's add only about .02 microns, you should see 1-2 microns with OC when applied correctly.
So that would be a great way to add back protection if one decided to level their paint and get rid of the orange peel? If you were religious about maintaining the Opti Coat seal with further applications on a timely matter you could add the amount of clear reomved and end up with the same measurement before you leveled the clear?
Sorry, I just got this idea running through my head. I dont plan on leveling my paint anytime soon but with the new seleants that you and others have brought to the table just got me thinking. Just curious.
Optimum Guru
When cars are preped on assembly lines the compounding a polishing steps to remove sanding marks removes 2-4 microns. It's safe to say that a two step reconditioning would be comparable unless we're very aggressive, so you could add back some...but probably not as much as you've removed. The ability to add some back permenantly is huge though and will allow you to correct 1-2 microns in the future without hitting factory paint again. Our coating allong with education about proper care and avoiding over polishing can be invaluable for those wanting to protect their investments.
Optimum Guru
Originally Posted by Marc08EX
Does it degrade the longevity of the OC2.0 stored inside the syringe after transferring it back?
No, it won't degrade it if replaced timely. Exposure to moisture and air can cause polymerization to start, but containment in the sprayer for no longer than is necessary to coat a vehicle will do no harm. Removing the exposure by storing the remaindier in the syringe after use will stop polymerization.
I know Nick transfered the whole contents, but I usually only transfer 10cc as that's what I use on average.
Hey Chris,I just watched the OptiCoat2.0 video over at your forum and liked Anthony's yellow pad/latex glove/blue shop paper towel method.
I wounder how application would go using Anthony's method,with a small spritz bottle to cover the blue shop paper towel?
BTW,If I had a compressor.I would be all over the OptiSpray Gun/OptiCoat2.0
Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
Thanks for the reply Chris! Much appreciated!
I may have to revisit OptiCoat2.0 beause Anthony put about (3) coats of it on the black vehicle (in the video),and the finish did not looked stained(High Spots)
By nodule in forum Auto Detailing 101
Last Post: 12-29-2015, 11:10 PM
Last Post: 05-22-2014, 10:55 AM
By panthercz in forum Product Reviews
Last Post: 07-29-2012, 04:26 PM
Last Post: 04-30-2012, 06:03 PM
By muyo in forum Show N' Shine
Last Post: 11-15-2011, 06:08 PM
