Results 1 to 5 of 5
    Tips for removing Type I Water Spots
    Meguiar's and Duragloss both make water spot removers that may work for Type I Water Spots.
    Note: While Duragloss recommends their product for automotive finishes, Meguiar's only recommends their product for Marine and RV surfaces, so take this into consideration when choosing and using a product outside the manufactures recommendations.
    I have successfully used M47 on automotive paints to remove mineral deposits but that does not mean it will work for you on your car for the type of mineral deposits or water spots on your car's finish. Always do a Test Spot and make sure you're getting the results you want and hope for.
    Type I Water Spots = Topical
    These are Mineral Deposits or what people commonly call "Hard Water Spots". It's the minerals in water that people are referring to when they use the word "hard" in the term "Hard Water Spots.
    Type I Water Spots are primarily a mineral or dirt deposit laying on the surface of paint. Type I Water Spots can be the results of minerals suspended in city water or well water that are left behind after the water evaporates off the finish. This can happen by washing a car but not drying the water off the paint or if a sprinkler goes off next to the car covering the car with water drop that are not dried off the paint.
    Type I Water Spots can also be dirt or pollution particles left behind after water from rain or inclement weather evaporates of the finish. Type I Water Spots can also be Type II Water Spots in that the water can leave both a deposit on the surface and an etching in the finish.
    How To Remove
    Type I Water Spots can usually be removed by washing or wiping the pant clean using a normal car wash, rinseless wash, waterless wash or spray detailer. There are also specialty products just for this including,
    Specialty Products for removing water spots,
    • Duragloss 505 Water Spot Remover
    • Meguiar's M47 Marine-RV Hard Water Spot Remover
    The first sentence in the product description on the back of the Duragloss label reads,
    Formulated to easily remove water spots caused by impurities, (CALCIUM), in water.
    Duragloss states it can be used for automotive finishes and it won't remove durable polishes. My guess is they are using the word "polishes" generically to mean waxes, paint sealants or coatings, not abrasive products used to remove swirls and scratches. Duragloss calls all their paint sealants polishes. See the chapter on polishes for more information.
    The first sentence in the product description on the back of the Meguiar's label reads,
    Specifically formulated to chemically break down and remove hard water Minerals off the surface.
    When I worked for Meguiar's the common question about this product is can it be used on automotive paints and the company answer at that time was all the field testing was done on Marine surfaces in Marine environments.
    My experienced guess is that it won't in and of itself harm a clear coat surface.
    Two comments...
    The average person doesn't know the difference between a topical mineral deposit, (Type I Water Spot), or a sub-surface etching, (Type II Water Spot), and the average Joe Consumer buying this product to use on a modern clear coat to try to remove Type II Water Spots would be let down as they don't understand you would have to abrade the paint with a compound to remove Type II, thus they designate a product like this to the Marine market. Just my guess.
    Vinegar
    A common recommendation for removing water spots is to wipe the paint with vinegar, they kind you find in a kitchen pantry. If the water spots are in fact mineral deposits sitting on the top of the paint then this may work but you won't know until you try.
    How Vinegar Works - (If and when it works)
    Common cooking vinegar or food grade vinegar is a weak form of acetic acid, which is has low pH. Mineral deposits are just that, minerals that are either dissolved in water or embodied in water and when the water evaporates it leaves the physical mineral behind on the surface.
    There are different types of minerals in water but one of the most common is Calcium Hydroxide. Calcium Hydroxide has a high pH, if the mineral deposits on your car's paint are Calcium Hydroxide, then the low pH Acetic Acid in the Vinegar will act to neutralize the high pH of the Calcium Hydroxide and either dissolve the minerals or break their bond to the paint and at that point you would be able to wipe them off the surface.
    If the hard water spots are some other type of mineral deposits, then there's a good chance the acetic acid in the vinegar will have no effect and in a worse case scenario cause more harm than good. This is why in the forum world you'll often read accounts from some people where they share how great vinegar worked for them in their situation but then you'll read accounts by other people where the vinegar had no effect.
    The problem with using Vinegar is that the acetic acid will act to remove any wax or paint sealant previously applied to the paint, wiping a waxed finish with vinegar certainly won't add more protection and what's the opposite of adding?
    The other problem with using vinegar is that in and of itself it doesn't provide any extra lubricating ability outside of being a liquid. So using it with some type of cloth, for example a microfiber towel will not be as gentle as using a product formulated by a chemist specifically to be wiped over polished finish. And if fact if there are physical minerals on the surface then wiping them off without some type of added lubricity could in fact lead to scratching of the finish.
    The two products show above, Duragloss 505 and Meguiar's M47 are manufactured by reputable companies and I'm confident the chemists have taken into account everything involved with creating a product for Joe Consumer to potentially wipe a clear coated finish to remove mineral deposits.
    Remember clear coat paints are scratch-sensitive, that is they scratch easily. I think it's safe to assume that any product created by a reputable company for wiping off mineral deposits will include both lubricating agents plus glossing agents along with their proprietary ingredients for forcing the minerals to release their bond to the surface.
    Key Benefits
    The lubricating agents help prevent potential scratching from the minerals on the surface and the glossing agents restore a just detailed look to the finish.
    These two included features to the products are important to car owners even thought most car owners probably don't even know they want and need these benefits from the product.
    Vinegar offers neither of these benefits.
    My recommendation
    If you find you have what I call Type I Water Spots, that is what the world generically refers to as Hard Water Spots or Mineral Deposits, then obtain one of the two products listed in this article, especially if the spotting is an ongoing problem and give them a try. Other safe options would be to try a spray detailer, (at least it offers lubricating and glossing features), or try washing the car using a high lubricity car wash.
    If you do opt to try vinegar, test first to a small area. Dampen a clean, soft microfiber towel with vinegar, place it on the affected area and allow it to remain for a few seconds so it can soften and hopefully dissolve the mineral deposits, then gently wipe the surface. This would be a safer approach then wiping dry paint with dry mineral deposits bonded to the surface.
    Important
    If you use vinegar to remove water spots, plan on re-applying some type of wax or paint sealant afterwards to restore any protection removed from the acetic acid.
    Re: Tips for removing Type I Water Spots
    ***Bump***
    For Jim who just called asking about using vinegar to remove water spots.
    Here you go Jim and be sure to check out some of the other threads on our forum, you'll find tons of information on detailing your cars...
    Super Member Bunky's Avatar
    Jun 2007
    Hillsborough, NC
    6,201
    I have used the Duragloss.
    It worked nicely following washing in less than good conditions (hot, water stayed on paint) when detailers using during the drying process (like PB's Spray and Wipe and others) did not.
    It smells like vinegar but the chemical name on the label is not acetic acid.
    Al
    The Need to Bead
    Quote Originally Posted by Bunky View Post
    I've had good luck with both products pictures, the key feature for others to consider when thinking about using vinegar is that vinegar doesn't offer the lubricity either of these product provide so you risk marring or even scratching your car's finish.
    Super Member DogRescuer's Avatar
    Apr 2013
    Hurt, Va
    1,801
    How To Remove
    Two comments...
    Vinegar
    Key Benefits
    My recommendation
    Important
    Mike great article, I need something or some idea in removing more type 2. Any suggestions?
    Steve
    -The Titanic Was Built By Professionals But The Ark By Amateurs-
    "Boanerges"
  1. 3 - Types of Water Spots - Type I, Type II and Type III
    Last Post: 06-18-2019, 07:03 AM
  2. Water spots in Houston Type 2
    By aether850 in forum Auto Detailing 101
    Last Post: 06-09-2014, 08:04 AM
  3. What type of vinegar for water spots?
    By Kaban in forum Auto Detailing 101
    Last Post: 09-12-2011, 09:23 AM
  4. Tips: Removing wax from plastic trim and water spots from windshields
    By NorthernVaBMW in forum Auto Detailing 101
    Last Post: 06-01-2011, 02:05 AM
  5. Removing type water spots/etching
    By ronin in forum Auto Detailing 101
    Last Post: 09-18-2008, 08:08 AM
