Results 1 to 4 of 4
    Junior Member reggie1967's Avatar
    Oct 2010
    85
    the correct way of applying clear coat to headlights with out streaking
    what up group some time i have a problem applying clear coat to headlight with streaking on headlight i been catching my self taking off the clear coat with minerals spirits and re applying i have been using the dvelup headlight clear coat/ and i have a better result with the mini wax clear gloss/ with minerals spirts what you think
    Reggie"S Headlight Restoration lancaster sc/ charlotte nc area
    Super Member 93fox's Avatar
    Dec 2010
    Houston TX
    1,076
    The correct way of applying clear coat to headlights its by sanding them and finishing off at 1000grit. Then with a spray gun you shoot clear on them. Now i dont know what clear you are using but a "clear coat" consit of clear and hardener. What stuff are you exactly using?
    Hi !
    Aug 2010
    New Jersey
    15,173
    Re: the correct way of applying clear coat to headlights with out streaking
    Quote Originally Posted by 93fox View Post
    Dvelup is a headlight reconditioning system. I think I'd just use Opti-Coat.
    Oct 2010
    85
    i used dvelup headlight restoration clear coat 2 part mix and also use mini spar clear coat glosse and minerals spirts mix depends on level of sanding i do ranges from 220 up tp 3000
  1. Protecting Headlights - Clear coat & PPF Film?
    By AMarkham40 in forum Auto Detailing 101
    Last Post: 12-21-2019, 11:37 AM
  2. Clear coat failing on headlights?
    By irvsmith in forum Auto Detailing 101
    Last Post: 04-21-2018, 08:09 PM
  3. Replies: 12
    Last Post: 06-23-2017, 03:08 PM
  4. How to remove clear coat spraypaint from headlights?
    By Eldorado2k in forum Auto Detailing 101
    Last Post: 03-09-2016, 02:08 PM
  5. How to remove clear coat on Headlights
    By PearlWhiteGT in forum Auto Detailing 101
    Last Post: 09-16-2008, 11:46 AM
