Page 8 of 8 FirstFirst 12345678
Results 71 to 72 of 72
  1. #71
    Aug 2010
    New Jersey
    15,198
    Re: Understanding headlamp repair
    Quote Originally Posted by Qusai View Post
    Im sorry if you guys already mentioned in between pages 2-7. Is it possible to seal headlamps after sanding and buffing to keep it looking new? If not then I would really like to know because I know nothing about this subject. Thank you
    Yes the is the "spar urethane" method which uses consumer-available wood coatings for a permanent repair (depending on your definition of "permanent"). Some of us have used Opti-Coat 2.0 which works but appears to lack enough UV inhibitors to make it permanent; however, Optimum is poised to release a specific headlight product called Opti-Lens which will be available to professionals and is said to be a permanent solution. Rumor has it that a consumer version of this will also be available which may have less longevity. And lastly, you can use professional headlight coating products as noted in this thread, which may require professional spray equipment, UV curing lights, and may not be available for purchase through retail channels.
  2. #72
    Junior Member pedro_paydro's Avatar
    Nov 2012
    fort walton beach, fl
    90
    what is the clear you used on those headlights? seems like a ready mix of some sort..please share your secret ;D
    00 celica gts; manual
    roses are red, i like jello
    this makes no sense... feel silly huh?
  1. Understanding customers and their needs.
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 03-11-2018, 12:07 PM
  2. Understanding PTG readings?
    By parttimer in forum Auto Detailing 101
    Last Post: 05-06-2014, 10:22 PM
  3. Understanding Orange Peel
    By birdog in forum Auto Detailing 101
    Last Post: 08-09-2013, 06:08 PM
  4. I need help understanding the speed
    By Lucian in forum Rotary Buffers
    Last Post: 04-02-2011, 10:13 AM
