Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 72
  1. #21
    Super Member sohail99's Avatar
    Aug 2010
    921
    Re: Understanding headlamp repair
    I have a aerosol can of automotive 'Acrylic laquer'. I never tried it on plastics though!
    btw after spraying clear, is there a need to sand, refinish to flatten out the clear?
  2. #22
    Aug 2010
    New Jersey
    15,169
    Quote Originally Posted by sohail99 View Post
    I'd be careful with that...I did a wheel repair and finished it with some clear "high performance wheel coating" which proceeded to yellow over time. If I had known at the time I could get the 2K in a can I would have done it. Just use a proper respirator if you're going to spray the 2K.
  3. #23
    Super Member SeaJay's's Avatar
    Aug 2010
    Billerica, MA
    3,070
    Nice info Barry, thanks for the write up. Also, thanks for all the follow up posts. Answered all my questions that I had.
  4. #24
    Nov 2009
    Pasadena, CA
    12,615
    Quote Originally Posted by Shiny Lil Detlr View Post
    You can get 1K clear at most auto parts stores, as well as both 1K and 2K clears from any local PBE distributor. One of my favorite clears is sold under the brand "SprayMAX." I pick it up at Finishmaster locally.
    Charlie,
    Is this the same thing?
    Amazon.com: USC Spray Max 2k High Gloss Clearcoat Aerosol: Automotive
    '03 Corvette Z06
  5. #25
    Super Member LegacyGT's Avatar
    Aug 2010
    Des Moines, Iowa
    2,090
    This is awesome information, subscribed
    Detail Fest 2012 Face Book Page
    Club Flex 3401/PE14-2-150
    -Bill
  6. #26
    Super Member Gurge's Avatar
    Aug 2010
    Ormond Beach, FL
    521
    great info
    for the guys already using the 1k & 2k clear coats, whats the cure time? as in when can the car be driven. some of the descriptions on these products say 12 hour cure time
    also, any 'wipe on' alternative to the aerosol? (opti coat i guess is an option) I work outside pretty often and with the wind on some days I wouldn't dare spray any paint
  7. #27
    Super Member 93fox's Avatar
    Dec 2010
    Houston TX
    1,076
    Quote Originally Posted by Lasthope05 View Post
    Excellent thread Barry. Now people can finally see a true headlight restoration and not just sanding, buffing, and applying furniture clear on it. I've been preaching and doing it this way for a while now only with sanding up to 800gt and using a 1k clear vs a 2k.
    People dont understand that you need a rough sanded surface, not a smooth polished one, for the clearcoat to adhere properly.
    You are right about saying this is the correct way of doing it. Clearing them will last a really long time, i know this since i smoke out headlights and tailights this way too. But you have to understand that not everyone out there is willing to pay for a job
    Done correctly this way. And thats when the "furniture clear" comes in. If they are willing to pay for something cheaper then you can use the uv sealent trick. Remeber, you get what you pay for.
    Hi !
  8. #28
    May 2009
    4,837
    Quote Originally Posted by 93fox View Post
    Are you offering a warranty with your furniture clear? Do you know how long the furniture clear lasts? I'm curious.
    On a side note, looks like we have a new test to run - furniture clear, UV coating, Opti-Coat. Who wants to be the one?
  9. #29
    Super Member Lasthope05's Avatar
    Aug 2007
    Philadelphia, PA
    1,113
    Quote Originally Posted by Gurge View Post
    great info
    The one I use (SEM 1k HS Clear) is dry to the touch and can be handled in 1 hour. I also place the halogens next to the headlights to make it dry slightly faster but dont try to force dry it as you will get fish eyes and bubbles in the paint. Full cure time would be about 12-24 hours just like sealants. It needs time to fully out gas.
    I have never used the furniture clear technique so I wouldnt be comfortable with doing it for customers. Im sure it might work fine for a while but coming from an auto body repair background, applying a clear to a smooth polished surface doesnt sit well with me.
    Alan T.
  10. #30
    May 2009
    4,837
    I see where you are coming from but I have to ask - what is your stance on Opti-Coat?
    Barry, I have no intentions of hijacking this thread. Like I said before, this is excellent information that I'm certain someone will put to use.
  1. Understanding customers and their needs.
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 03-11-2018, 12:07 PM
  2. Understanding PTG readings?
    By parttimer in forum Auto Detailing 101
    Last Post: 05-06-2014, 10:22 PM
  3. Understanding Orange Peel
    By birdog in forum Auto Detailing 101
    Last Post: 08-09-2013, 06:08 PM
  4. I need help understanding the speed
    By Lucian in forum Rotary Buffers
    Last Post: 04-02-2011, 10:13 AM
