Re: Miscible and Immiscible - Wax and Paint Sealant Bonding
Originally Posted by Mr Megane
I guess what I am in fact alluding to is that the use of terminology in this area is rather ambiguous and what the user perhaps expects from the product category may not match entirely what the product is doing.
Mind you - the terminology is a lot better than what the chemical industry uses.
Talk to the big manufacturers and a polish could mean anything from a pure cleanser through to a wax with heavy compound abrasives!
I strongly agree with the above and in fact... I have an article on that...
Words mean things... just ask any Lawyer...
Word Definitions - Compounds, Polishes, Glazes, Paint Cleaners and Waxes
So are you saying after compounding and polishing that it may be necessary to apply a light isp for proper bonding of sealant/wax? Wouldn't just wiping off polish/prewax cleanser be good enough before waxing? I understand if working on more expensive cars this step might be appropriate as to perfection but Mike stated "working forward" would also be to apply a light polish before waxing. Isn't that the last step one would normally do before sealing/waxing? Compound >polish>wax. or isp compound polish wax or compound polish, isp wax? thanks Godbless
Shaun Halstead Aka "shaunny blaze"
Christ Lightning Detailing
Grandslam Detailing
Actually, if you go to the first page of this thread and read the second paragraph what "I" say is to follow the manufacturer's directions...
Follow the Manufacturer's Recommendations
The first and primary consideration goes to the manufactures recommendations. If the manufacturer of a wax or paint sealant officially recommends that the surface of the paint must be stripped clean before their product can properly bond to the paint, then you should follow the recommendations of the manufacturer as they know their products best.
If the manufacturer does not specifically recommend that a painted surface needs to be stripped clean, then whatever recommendations they do provide should be followed as they know their products best.
To my knowledge, there are only a few manufacturers in the wax and paint sealant business that recommend that the surface of automotive paint be surgically clean and bare before their products can be applied. Besides these few companies, most manufacturers either recommend to apply their wax and/or paint sealant to the paint after first using their surface prep products which can include, compounds, polishes, paint cleaners and pre-wax cleaners. And of course, sometimes there are no specific recommendations.
It all depends upon what the manufacturer recommends. For example, most if not all coatings manufacturers recommend an oil, wax and silicone free surface before applying their coating.
So for any product you want to use, check to see what the "manufacturer" states about the proper use of their product.
Historically, the above would be correct and still is for the majority of car wax and paint sealant manufacturers. Coatings are a new evolution in paint sealing and protection.
That's what this forum is all about... introducing new products and the education to use them correctly be they a tool, pad, coating, etc.
Thanks for the clarifications. I never even heard of ipa's . See it's good to be on these forums. I 've heard of prewax cleansers but only for car whose paint does not need any correction. I guess I was under the impression since i basically use all meguiars products that they all work together and would be chemically miscible and the compounding/polishing would not hurt the adhesion of any type of sealant/wax, but I guess it couldn't hurt to allow for more complete bonding! Thanks for the tips again. Blessings.
So do yall pros, Mike, and others actually use ipa's on every car ? And only before waxing/sealant?
Offsubject- Have yall heard of that new simoniz sealant supposed to seal your car for 5 years?
Grandslam Detailing
I'm looking for a little practical advice on this topic as it relates to the Klasse family of products.
The last time I read the AIO or SG bottle it talks about a "clean, dry surface", but doesn't say "fully stripped". I fully understand that SG won't bond real will if AIO isn't under it. My question centers around the surface conditions prior to AIO application.
I recently moved from the agricultural age and into the industrial age when I bought a DA polisher. After practicing on a "beater car" I'm ready to move on to one of the family daily drivers that needs some minor paint correction.
I'm planning on using Meguiars UP for the minor correction, but don't know if I should do a IPA/MS wipe down prior to applying the AIO. Does the Klasse AIO have enough cleaning action to remove the oils from the UP to ensure the SG bonds properly, or is a wipe down in order?
After reading Mike's great article on IPA mixing and usage, I'm a little hesitant to do a IPA/MS wipe down and would like to avoid it if possible.
I'm not a chemist and I never try to play one on the forums so knowing 100% what a product like Klasse AIO will and won't do is hard to know for certain.
How old is the car? What condition is the paint?
Factory paint that is brand new is not very permeable, that is is is very solid or dense, the opposite of porous.
The point being, any polishing oils left over from the Meguiar's Ultimate Polish will be pretty much topical, that is on the very top of the surface. My guess is that the cleaning agents in the Klasse AIO will pretty much mix with these and then remove them when you wipe the Klasse AIO off. Just a guess.
I'm not a big fan of wiping paint with IPA and state that in the article. If fact I state that I didn't even want to write the article in the first place and a year before I wrote it I put out a general request for ANYONE to write it.
The reason for writing it was because there were a handful of people that were always telling people to wipe their paint down with alcohol all the time without any real knowledge of what they were actually telling people to do. Kind of a no accountability no responsibility for what they were posting and telling other's to do with their paint.
After a year went by and no one took it upon themselves to write the article I finally did just to try to help protect people from making mistakes.
Here's the deal for decades now people have been using the Klasse Twins, that is applying the AIO first followed by the SG without any issues and in fact you'll find more success stories and positive testimonies about experience's with the twins than you'll find horror stories.
If it were me and my car's paint, I follow the tried and true plan...
The vehicle is about nine months old and the paint is in pretty good shape except for some dealer installed swirls I'm going I'm going to attack.
That was my thought too. My main goal is to avoid creating an oil/sealant stew the SG won't bond with.
I'm not a big fan of wiping paint with IPA and state that in the article. If fact I state that I didn't even want to write the article in the first place and a year before I wrote it I put out a general request for ANYONE to write it...After a year went by and no one took it upon themselves to write the article I finally did just to try to help protect people from making mistakes.
I could gather that from the tone of your writing. If you're reluctant, I'm going to be very hesitant. The next time I order up some products I may get a paint cleaner just to play it safe.
I'm one of those folks who have been using it forever...about nine years now. However, this is the first time I am using it following a polish. In the past I've always gone from the clay straight to the AIO.
Thank you very much.
Reason: Fix typos and other errors
Originally Posted by RaskyR1
I couldn't agree more Mike! I actually have that Meguiar's link bookmarked for when discussions come up on the forums that relate to it.
The original article I wrote on MOL is good but I'd say this updated article is better, at least more in-depth.
I typically just give the car a good wash with a regular car soap after polishing. No IPA wipe downs for me. I actually feel like IPA and other similar solvents dry the paint out...just look what it does to your hands.
Yeah I've never been a big fan of IPA wipe downs. IPA doesn't work well as a lubricant so you risk marring the paint.
Since I wrote this article a few new products have been introduced to the market for cleaning the surface without the risk of marring it.
A "careful" wash job will accomplish the same goal as chemically stripping with IPA. The chemist at Meguiar's always used MS for their purposes and MS actually wipes pretty good but I rarely use it now days.
The only time I have been wiping cars down to prep the surface is for paint coatings like Opti-Coat and CQuartz, which is actually recommended by those manufacturers.
Exactly. Follow the manufacturer's directions. A few years ago I checked with Dr. David Ghodoussi about this topic and he said as long as you're using Optimum compounds and polishes you could use a water-dampened microfiber towel to wipe the paint down before using Opti-Coat.
One thing about clearcoat paints that I think a lot of people don't know or understand is they are not very porous, so there's not a lot hiding places for polishing oils and other substances to bury into and everything is pretty much topical or on the surface, so it doesn't take much to strip any residual polishing oils off the surface of clearcoat paints in great shape. Thus... as you say you do, a quality wash job should remove anything of any concern off the non-porous surface of a clearcoat finish.
Now old school single stage paints... their a completely different animale...
Mike, I remember you stating and showing pictures of how too high of IPA to water ratio can actually cause paint shrinkage as well. It seems like with the product technology boom that we have in today's detailing world, IPA is taking a back seat to better, albeit pricier, options. There are wash soaps and spray on products that will strip oils and LSP's safely and without much effort. For me, the bottle of IPA sits on the shelf collecting dust most of the time because I have other products that are safer and produce better overall results.
By frankprozzoly in forum Auto Detailing 101
Last Post: 07-03-2014, 08:40 AM
By Nate3420 in forum Auto Detailing 101
Last Post: 06-12-2013, 06:17 PM
By NAVYJOE11 in forum Auto Detailing 101
Last Post: 10-04-2012, 06:45 PM
By RPPM in forum Auto Detailing 101
Last Post: 02-16-2012, 04:56 PM
Last Post: 11-01-2010, 02:59 PM
