Dislikes: 0
Super Member
Entire Process for C6 Owners , and obviously all others !! (Long Post)
I have to admit to an extent I am lazy , why ??? Because I have been PM'd or asked thru email at least 10 dozen times how I keep the Vette looking good, and whats my technique. I usually rattle off a couple of items, and we correspond back and forth numerous times. So ... with a little time, and effort on my part I have made some notes and pics to help you all.
First, swirls are indicitive of paint seeing something abrasive come across it. Dirt, washing, drying, rough towels, and numerous other items can induce swirls. To alleviate them entirely cannot be done , but hopefully some of these steps will help you see some ways in which to reduce them. Once we have them we will need to "hide" them thru filling, or "remove" them thru polishing. We will do it in the correct fashion below.
Wheels
First, lets start with an area closest to the ground that should not touch paint. You will need a soft towel and wheel cleaner specific to your wheels. I am using P21S as is safe on all wheels, and my Iforged Wheels are not clearcoated and thus easily damaged. I spray on liberally, and then use a soft small microfiber to aggitate the dirt. I then soak the wheels liberally with water to remove soap, dirt, and any contaminents.
Before -- Dirty
After --- Notice Additional Shine
Super Member
Washing
My first line of attack is to study the paint, and how bad it is. Would a standard wash work, has the crispness ended ?? In this case the car is not extremely dirty but the reflections (see leaves, not very sharp) are not as well defined. Now this has a little to do with overcast day, but we certainly can "jewel" the paint a bit.
I get out my handy foam gun (soap, soft microfiber mitt, a bucket) and I proceed to mix my first batch (the presoak). I then spray the entire car with a good batch of it, before readding soap/water to foam gun, and filling my bucket with lots of clean water. (we change that after 1/2 car)
As you can see the car is quite foamy and the soap is doing some work by moving some contaminents away from the paint prior to me jumping in. Now my next technique involves spraying each panel right before washing it. I also wash in straight lines, never circles. After each panel the mitt is washed out in the clean bucket of water. Usually at 1/2 point I wash down the car with water, and refill bucket. Since it was cool and overcast, I moved on after just refilling bucket.
The car has now been washed, used a liberal amount of water to truly wash down the car, any remaining dirt and soap and have a clean palate to work on. I could also clay at this point, but paint feels great based upon baggie test, so we will skip it this time, and rehit at the 4 month detailing session.
Super Member
Super Member
Polishing
This stage is the hardest because you will need alot of practice to grab the correct polish and the correct pad. Since paint was not in too bad a condition, I went with a final polish and a medium pad for a little more bite.
This area is likely to big for a beginner, it is however a cool day and overcast and the polish I chose allows ample polishing time. What I want you to note is the overlapping. What you cannot see is speed. The PC is at full tilt from just after intial spread (3) to finish. Work your areas for 5 minutes on average and allow the polish to haze and talc as it diminishes the abrasives, stopping to soon, is like rubbing sand paper across the paint.
After each panel wipe off the area, and look for additional swirling and reflection. You should have easily removed any oxidation making paint look new, but swirls can take alot longer. Using an alcohol/water wipe is good idea as it will remove any fillers the polish might contain.
Super Member
Protection
Well the polishing really worked (we will see shortly), and we are ready to protect our work. So do we wax or do we seal ??
seal --- durability , reflection, crispness, gloss
wax --- wetness, depth, richness
Today I decided to seal, and thats because I have found several newer sealants (UPP, Duragloss, DP) that are less plastic looking, and really add to black. I also plan on waiting till February to redetail as possible.
Note two items in this picture. First, the sealant (as is all sealants) is added as thin as I can handle. The game in not to gunk it on in hopes that more is better. Also note, I am still trying to apply/remove in straight lines. Circles can equal swirls. I did two coats back to back with about 4 hours inbetween, in a perfect world it would have been a little longer, but time management was also a key point in wife allowing me to waste part of Saturday during the Holiday season.
Super Member
Final Check, Wipe Down, Dress Tires
Well this is where we pull her out and hope all went well. Garages are easily known for reflection as most light is refracted and darker to begin with. We really need the sun or natural light to guage our work.
I then like to rewipe certain area's with a qd'er+ type product to really add some umph to paint. This is a competitors spray but I have found it quite nice to work with in any sealant situation. Quikshine, Crystal Mist, Aquawax and more would also be acceptable and you can wait several hours as possible.
I would also now consider dressing the tires. No longer will you be moving any towels around the area where they could pickup and move onto paint. Remember to also dress any noticable trim, especially the dust guard under the front, and even the 5th tire on SUV's if you can see them underneath the bumper. I also use some Plexus on the headlamps and the tailamps to renew them. If you got any polish/sealant/wax on glass, this would also be a great time to remove.
Super Member
Noticable Difference in Detailing Properly
Before -- on what most would consider to be kept up !!
After
so was it worth the time needed to detail correctly ?? Maybe we should have just flown into a touchless wash, and been done. You decide !!
Super Member
Super Member
Great write-up killr! I was just getting ready to pm you to ask your process jk But it is nice to know your process since you hear alot about how mard the Vette's Clear is. Your car looks awesome. Thanks
Great write up
I hope you don't mind if I ask a question, however... I dressed my wheel wells for the first time today (looking great!) but I'm having some trouble as far as the areas that aren't directly near the tire (like further back in the well). What is the best way of getting there? I can't really get my towel I was using to wipe down the AA tire foam back there, and couldn't really fit the can in there to spray (I didn't want to spray from far away and risk getting a mess all over, including the tread of the tire).
My tC is stock height as well, so techincally I have a lot of space to work with (so not sure how I'm supposed to do it when I finally get it lowered heh)... how do you do it with your tight wells?
thanks, sorry for the verbose question
Similar Threads
By CWallace in forum Auto Detailing 101
Last Post: 06-22-2012, 09:12 AM
By ALLN1WASH in forum Auto Detailing 101
Last Post: 04-06-2011, 07:18 PM
By Matt S. in forum Auto Detailing 101
Last Post: 02-09-2010, 08:41 PM
By ScottB in forum Show N' Shine
Last Post: 08-13-2009, 05:02 PM
By ScottB in forum Auto Detailing 101
Last Post: 09-30-2007, 10:22 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
