Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Re: Foam Pad Options for the Griots G9 Polisher
    Quote Originally Posted by seanktm View Post
    Can anyone verify that LC Force pads are not too thick for the G9's? Comfort is great with LC Force Hybrid, but wouldn't want to get more pad stalling in exchange...
    Also, would it be crazy to use thin pads (say BOSS) on the G8 and use thicker pads (say LC Force) on the G9 for correcting and polishing the same vehicle? My thinking is that the thinner pads can maximize the smaller profile of the G8 getting me to tighter places while a thicker pad can make using the G9 a little more comfortable.
    Yancy and I are in the garage all day shooting video and then I have a product to test out and write a review for.
    If I can - I'll stick a LC Force Hybrid pad on the G9 and see how it works.
  2. Likes Coatingsarecrack liked this post
  3. #22
    Aug 2020
    914
    Figured I'd mention this here. Griots redesigned their Microfiber Fast Finishing pad(6.5 inch). It used to be black with soft red foam and no center hole. Now it's white with a firmer red foam and a center hole. I think the new one is going to be more durable.
  4. Thanks RamAirV1 thanked for this post
  5. #23
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,247
    Any reason not to use the LC flat foam pads with the G9? Mike included the link but didn't mention them specifically. I get that pads with a hole would be preferred. I have a lot of these pads, particularly White, which is my go to for light polishing.
    I can invest in other pads if necessary.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  6. Likes RamAirV1 liked this post
  7. #24
    Newbie Member seanktm's Avatar
    Nov 2020
    Thank you so much! I am sure I can use it, but the future viewers will probably appreciate your comment on the combo as you have used the G9 with other pads and have something to compare with.
  8. #25
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by RippyD View Post
    None at all.
    I use the LC Flats with the G9, and they work like a charm.
    I do (as always) switch out pads like a mad man, though. (Upward of 20 on my Ram truck).
    So I cannot speak to someone trying to stretch 3-4 pads over a whole vehicle. (Not suggesting you would do that, Rippy).
  9. #26
    Jan 2016
    Portland, OR
    1,247
    None at all.
    Thanks for the confirmation, Paul. I have a ton of flat white pads and quite a few orange. And yeah, I changed them often. Depending on paint condition I can use one pad per panel. Maybe 2 if it's too contaminated.
  10. Likes PaulMys liked this post
  11. #27
    SELF BANNED
    Jun 2019
    1,076
    FYI for anyone that has the first generation G15, if you want to try different pads, i would recommend the DA rupes pads - fits excellent on the G15 backing plate. I also tried the LC SDO Orange, doesn't fit the original backing plate has well.
    I also enjoy a slightly thicker pad then the BOSS pads once i got used to them. I'm somewhat more skilled now though with correcting pad stalling. I tried to run my G15 at 3.5 at the beginning but i find it works much better at the 4.5 speed setting.
    Caveat: I'm a novice, just sharing my experiences Machine polishing is my favorite detailing process though!
  1. Mini/Nano Polisher options
    By tWiStEd-tORqUe in forum Auto Detailing 101
    Last Post: 01-06-2020, 10:23 AM
  2. 5.5" SUPER THIN FOAM PAD OPTIONS for your Dual Action Polisher
    Last Post: 12-31-2019, 12:14 PM
  3. Griots Boss Air 2" backing plate on Griots 3" mini polisher?
    Last Post: 03-31-2019, 03:08 PM
  4. Replies: 9
    Last Post: 01-08-2010, 09:18 PM
