Results 21 to 30 of 37
  1. #21
    Mar 2011
    PA
    5,792
    Re: Windshield water repellent
    2018 Colorado ZR2
  2. #22
    Dec 2018
    7,173
    Quote Originally Posted by pro 4x View Post
    There are video’s out from 2012. I don’t think it’s new. Looks to work as well as Griots Ceramic glass cleaner. Cheaper too.
  3. #23
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,169
    I applied Gyeon Q2 Quick View on my Ranger about 3 months ago and has held up very well, still repelling water quite strongly.
    Q2 Quick View is very easy to apply and remove.
  4. Likes BudgetPlan1 liked this post
  5. #24
    Sep 2013
    NJ
    I've found good results with Rain-X, but with a caveat: You need to use two of their products and it's a bit labor intensive.
    First, you need to do a basic clean of the window glass to get the bulk of the soil off. Then you're going to use the first of the products, Rain-X xtreme clean. It will strip the glass completely of any water spots, grime, oil, etc. I usually use a 4" stiff foam pad chucked into a low speed drill for this step. When you can mist water on the glass and it wets out and doesn't bead, then the glass is actually clean.
    Next apply the Rain-X. Be fairly liberal with it, keep the applicator wet but not dripping. Go over the glass twice, in two different directions to work it in. You'll be able to feel and see the difference as the product bonds to the glass. Let it flash off to a haze, then buff with a microfiber. You can mist on a small amount of water to help buff the glass.
    By using this process, I've had great durability out of the rain-x, even on the windshield where the wipers run. Every 4-6 months you can do a light 'refresh' of it with a small amount of rain-x on a paper towel, but you shouldn't need to go through the heavy cleaning/polishing step.
  6. #25
    Aug 2013
    St Louis metro (Illinois)
    5,809
    For those of you using products on your glass, have you seen any issues when using a glass cleaner after applying the glass sealant/coating?
    My issue is my back window. It is sloped on a pretty steep angle and doesn't seem to shed water naturally like the windshield does. I applied some Griots 3 in 1 to see if it would help. A couple weeks later I needed to clean the glass and when using my go-to glass cleaner SprayWay, it made a horrible mess. I ended up with a strange white residue smudged all over the glass. It became VERY hard to remove. Seemed almost like glass cleaner partially dissolved or caused a reaction with the 3 in 1. Never see that before.
    The experience has me thinking of simply coating the back window with Gyeon Pure Evo when I do the car when I coat it in a couple weeks, or trying a water repelling glass cleaner. My only hang-up with the glass cleaner is I hate having a product I'd only use on some glass surfaces and not something I'd grab and use everywhere. I've had bad experiences with putting any type of product on windshields.
  7. #26
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    I still stand by Rust Oleum's product. Rust-Oleum Shield H2O Rain Repellent Spray. Super easy to use, works as well if not better than true ceramics but again, far easier to use. Lasts months. I have the GYEON product and it's meh at best. Local Central Ohio give away to anyone who wants to stop by and get it.
    2023
  8. Likes Azure liked this post
  9. #27
    Apr 2021
    Ottawa - cool town!
    515
    I am currently looking for something, maybe over Rain X??? I have been using Meguiars Ceramic Wash & Wax and really like it, also have a bottle of Gyeon Bathe+ to foam cannon as well. I have noticed the Rain X could play better with the soap. So looking for something that will blend right togeather... ceramic I suppose??
    I can't seem to find the Rust Oleum mentioned above. Have looked at Mckee's, Blackfire, Tac, Griots, Gyeon, Carpro, Gtechniq, etc, etc. P&S looks interesting, but expensive. Any good product to play along with the ceramic soaps?? The Rain X is cheap and everywhere, just wants to push the ceramic off while the ceramic wants to take over...
  10. #28
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    P&S Vue is a great option. User friendly as well.
    Hopefully it is not as bad as their coating. They didn’t do a good job with it.
    @Stoner Car Care Invisible Glass Coating Reapplication & Water Behavior
    @Stoner Car Care Invisible Glass Coating Reapplication & Water Behavior - YouTube
  11. #29
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by Silly Rabbit View Post
    on back order a lot of places. I have a bottle of the older and now newer version. Can't really complain about either. Old formulation worked awesome so you can't go wrong. It's up on eBay from a seller I've purchased from before.
    Rust-Oleum Shield H2O Rain Repellant Spray 11 oz. | eBay
    2023
  12. Likes Silly Rabbit liked this post
  13. #30
    Dec 2018
    7,173
    Yeah a lot of coatings are glass safe except windshield. I will probably do same
  14. Likes Desertnate liked this post
  1. Longest windshield water repellent
    By 01AUDI in forum Auto Detailing 101
    Last Post: 12-07-2017, 10:42 PM
  2. Fabric Convertible Top Water Repellent? (one that actually lasts)
    By NewShockerGuy in forum Auto Detailing 101
    Last Post: 05-07-2017, 07:42 AM
  3. remove old water repellent film on windshield?
    Last Post: 01-07-2016, 05:01 PM
  4. Gtechniq G5 Water Repellent Help
    By goldenlight in forum Auto Detailing 101
    Last Post: 04-18-2014, 10:36 PM
  5. 'Best' glass sealer/water repellent for a novice
    Last Post: 07-19-2013, 02:35 PM
Members who have read this thread: 7
