Results 11 to 20 of 31
    Aug 2010
    New Jersey
    15,171
    Re: All about the Defelsko Paint Thickness Gauge by Mike Phillips
    As Mike noted, the DeFelsko is a quality instrument, and I wouldn't have any hesitation picking that used one up--you might want to do the calibration check that Mike demonstrated above, and I'd probably want to check it on both steel and aluminum substrates.
    Jun 2014
    Chandler, AZ
    3,360
    High quality tool that every detailer must have if you're doing paint correction on customers vehicles.
  3. #13
    Aug 2016
    48
    Thank you, I'll make sure I bring a piece of steel and aluminum chip from work (flat) and test it out to make sure its within the 3%. If this all works out, I can take on more aggressive PC jobs with a little more insurance... assurance? lol
  4. #14
    Quote Originally Posted by Chramiji View Post
    Is there anything to look out for if buying second hand, it's out of its 2 year warranty period. One of my friend's buddy is letting his go since he moved away from detailing. So I have a chance of owning a Defelsko for a bit more than the Highline....
    I would test out the features like I show in the article above and then jump on this deal fast before he changes his mind.
    The Defelsko is a super high quality tool that is also incredibly accurate. The copies are just that.... copies and you get what you pay for.
  5. #15
    Aug 2016
    Howell, Mi
    118
    Have you recorded roughly the same area after waxing or after buffing then waxing.? I am going to get this gauge soon. Thanks Mike
  6. #16
    Quote Originally Posted by Dandy98 View Post
    I've measured these types of things a lot in my life.
    You won't see much difference with waxing but you will see a little with compounding.
  7. #17
    Super Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Pretty cool Mike
    Sent from my SM-N920V using Tapatalk
  8. #18
    Quote Originally Posted by Joe@NextLevelDetail View Post
    Pretty cool Mike
    Thanks Joe...
    You yourself knows how much time goes into taking good pictures and writing a how-to article that is both helpful and accurate.
  9. #19
    Super Member Mike Honcho's Avatar
    Apr 2015
    Atlanta
    1,264
    That is a cool tool!
    Mike Honcho
  10. #20
    Mar 2017
    Mike-
    Great article! When is your follow up on "How and Why" to use it coming out? I have a Defelsko combo and get it to work great (consistent) on the bench, but struggle with consistency of readings on vehicles. I've been taking pictures of the vehicles, printing them and writing my readings on the pictures.
    My concern is that my readings are inconsistent at the same locations (plus or minus 7 microns-ish)....with most of my readings in the 90 - 100 micron range. I know the vehicle has never been "corrected" before as I've owned it since new. I want to get consistent with the defelsko before moving on to much more expensive vehicles.
    Thanks in advance,
    Bret
  1. Replies: 8
    Last Post: 02-29-2016, 10:54 PM
  2. $200 Paint Thickness Gauge
    By swanicyouth in forum Ask your detailing questions!
    Last Post: 06-28-2012, 08:28 PM
  3. Defelsko PosiTest DFT Combo Electronic Paint Thickness Gauge Question
    By Perfections in forum Wet-Sanding, Cutting & Buffing
    Last Post: 10-12-2010, 04:48 PM
  4. Defelsko PosiTest DFT Combo Electronic Paint Thickness Gauge
    Last Post: 10-06-2009, 11:24 AM
