Re: Remove swirls scratches by machine in Vinyl Stripes Decals Graphics Corvette
Originally Posted by
Jacob Harrod AUTOCLEAN
Hey Mike, in this video you used the Pixie, Rupes soft foam finishing pad and Pinnacle Advanced Finishing Polish.
Mike Phillips - Vinyl Graphics - Removing Swirls by...
I'm assuming this is the fist pad and product combo you used on your test spot as this seems to be a very gentle combo.
It's the first pad and product combo I used on THIS specific graphic and car. I've done this before with the same pad and product so confidence is high. And after doing a TEST SPOT but OFF CAMERA and proving to myself it would work - then I did it on camera.
Is that the Speedmaster Swirlfinder Light?
Yes and it actually works really well and gives you three different light spectrums, which does come in handy. Here's my review.
Review: Speed Master Swirl Finder Detailer Light and Speed Master Swirl Finder Detailer Light Pro
The Speed Master Swirl Finder Detailer Light on black paint!
I just ordered the Pinnacle Advanced Finishing Polish. I noticed I only ordered an 8 ounce bottle. Is that enough to get around a whole car? If not I've got time to order another.
Probably if it's a small to medium size car. Also depends on you and how you use it. I believe I've compounded and/or polished medium sized cars with only 8 ounces a bunch of times in my life.
The product is REALLY good. It is expensive, but it uses great abrasive technology. Read the story I shared here,
Polishing Plexiglas to be as clear as glass using Pinnacle Advanced Finishing Polish
While the pictures are not only the real-deal they are also amazing. BUT the key is to READ the story.
Jacob - check your Private Messages.
