Results 1 to 6 of 6
    1970 Plymouth Barracuda - Super Contaminated with Overspray Paint
    Recently detailed this bitchen 1970 Plymouth Barracuda with a 440 Magnum engine, 6-Pack Carbs and Pistol Grip shifter - true Detroit Iron - true American Muscle Car History.
    I would say the most common place you find overspray paint are,
    1: Body shops or collision shops - not sure what you guys call them over here?
    2: Industrial areas where paint is sprayed outside
    3: A Car Guy's Garage - Car Guys are always using Rattle Cans to paint something and the overspray gets on their cool car.
    As you can see by the color of the overspray on the clay it's black and my guess is it came from some common rattle can spray paint used on or around the car.
    Just a guess....
    I used an ultra fine grade clay for this project and the reason why is because there were very little swirls or scratches in the paint.
    Because I have never worked on this car before of course I don't know if the paint is hard or soft, (or somewhere in-between), So I chose to error on the side of caution and use an ultra fine grade of clay.
    A more aggressive clay or a clay towel, mitt or pad may have marred the paint causing me to then have to remove the marring. So for cars like this I stick to least aggressive method to get the job done.
    Generally speaking, when it comes to removing overspray paint or other above surface bonded contaminants, the difference between an fine grade clay and an aggressive clay, (besides the abrasives in the clay), is the number of passes you make with the clay to remove the offending contaminants.
    With a less aggressive clay you make more passes, i.e. spend more time claying. With a more aggressive clay you make less passes and the claying step goes faster.
    But above all, as a professional detailer, I practice the Hippocratic Oath, which is an oath of ethics historically taken by doctors to,
    First do no harm
    I just apply this to car detailing or paint correction more specifically.
    On Autogeek.com
    Pinnacle Ultra Poly Clay - 2 Bars
    SONAX Glass Cleaner
    Sandwich baggies? Have to get them at the grocery store.
  2. Likes PaulMys liked this post
  3. #2
    Super Member davidc's Avatar
    May 2007
    Arizona
    1,499
    Re: 1970 Plymouth Barracuda - Super Contaminated with Overspray Paint
    Just a FYI. Anything with a 340 and above is a Cuda, below a 340 like a 318 is a Barracuda. Just a little nostalgia.
  4. Thanks oneheadlite thanked for this post
    Likes oneheadlite liked this post
  5. #3
    Super Member hoyt66's Avatar
    May 2011
    Oakland Mi.
    2,432
    Quote Originally Posted by davidc View Post
    Cool fun fact. Despite this being my all time favorite car I did not know this. Thanks for sharing
    2012 Dodge Challenger RT Classic Bright Silver
    2018 Ford F150 Xlt Sport 4X4 Magnetic Grey
  6. Likes oneheadlite liked this post
  7. #4
    May 2007
    Arizona
    1,499
    I would take the Cuda any day. No computers just basic muscle. I am a simple person and do not need the glitter.
  8. #5
    Quote Originally Posted by hoyt66 View Post
    Thanks for sharing
    I didn't know this either. Normally when I type - I try to be very accurate. In this example I was trying to be accurate with the full version of the word.
    It would have been easier to just type Cuda
  9. #6
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Call it whatever you want.
    That thing is BAD A$$!!!!
  10. Likes hoyt66 liked this post
  1. MOPAR Barn Find! 1970 Plymouth Cuda 440-6
    Last Post: 06-30-2021, 12:22 PM
  2. 1970 Plymouth Cuda Vitamin C Orange - Detailed by Mike Phillips
    Last Post: 10-30-2016, 11:40 AM
  3. 1970 Plymouth Roadrunner Superbird 440 Sixpack Limelight Green - This is going to hurt your eyes!
    By Mike Phillips in forum 3-Day CAR Detailing Bootcamp Classes - Info & Dates
    Last Post: 08-23-2016, 04:05 PM
  4. 1970 Barracuda Extreme Makeover
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 07-10-2014, 09:52 PM
  5. 1971 Plymouth Barracuda correction
    By gofast908z in forum Show N' Shine
    Last Post: 10-25-2012, 11:03 PM
