Re: Good rule of thumb when using an AIO - stick with foam polishing pads by Mike Phillips
Originally Posted by fightnews
Polishing pads leave haze on my paint. I need finishing pads and ultrafine polish to get it perfect. I did a test spot with a yellow rupes pad and fine gel polish and that left haze compared to the white pad with the ultra fine polish.
Thanks for sharing the above. Sometimes I think other people think I'm crazy when I tell them about
Pad Haze
Also - I have NOT found the RUPES yellow and even their white foams to be the softest of the available options.
I did a test spot with a yellow rupes pad and fine gel polish polish.
It was most likely the polish, not the pad. Their fine polish does not finish well, unless the paint is hard. Rupes yellow pad will finish better than softer pads, IME.
Last Post: 07-06-2021, 03:40 PM
Last Post: 10-05-2018, 05:16 PM
Last Post: 05-16-2017, 07:19 AM
Last Post: 05-02-2017, 06:34 AM
