Re: How To: Restore & Protect Headlights with Detailer's Total Headlight Restoration Kit
Originally Posted by riles32807
Anyone using the DP kit & sealing with opti-lens? Does the DP kit leave the lenses polished enough for opti?
Sent by carrier pigeon using AG Online
As a polish that seemingly is a final step on a restoration, I would assume so. I am going to be doing exactly this when it warms up outside! I will let you know how my experience goes.
So I tried this similar set-up yesterday, except I used meguiars headlight PlastX. I used a craftsman bolt on drill with the setting on the screw drill setting.
It worked out, I would say, pretty good. It took me 2-3 buffs and passes to kind of get it cleaned.
The problem I ran into was - the purple wool pad came ungluged from the hook and loop backing.
I was pretty bummed to have this happened. I constantly kept moving the pad, performing similar motions as with a DA polishes on the car. I felt that I had moderate pressure, but for some reason was not getting the results I was after. Anyone else have the wool part separate from the hook and loop section due to heat build up?
Is there a difference in abrasiveness with the DP all in one cleaner and the meguiars PlastX?
I coated the lens with the meguiars headlight protection liquid.Thank you
