Best way to clean door jambs
Hey guys, I'm new to the forum and have done some searching but haven't found an answer as of yet. I have a 2011 Mercedes-Benz C300 4-Matic Sport. After bringing to the dealer for my last service, it appears that hey lubed my door hinges, strikers and posts with some kind of a clear, thick and greasy lubricant. I made the mistake of wiping down my jambs after washing my car and it smeared this think greasy substance all over my door jambs. I have tried using car was soap, cleaner way, quick detailer and finally my last attempt was using CG "All clean" citrus based cleaner with a soft brush. Still, the substance is there and noticeable. I like my door jambs to be spotless just like my exterior and this is driving me crazy. What do you think I could do to get this cleaned up without damaging the paint?
Re: Best way to clean door jambs
APC or steam will work just fine.
Yep, steam or a strong apc.
Sent from my SPH-L710 using AG Online
Once it's all cleaned out you can use just soap and water, or some onr, and a mf towel for maintenance. I agree with everyone else as far as removal of the grease.
2010 Honda Civic LX-S Crystal Black Pearl
Thanks for the tips! I will give these a shot! Forgive me though, I'm new to the detailing acronyms... What does onr stand for??
Just remember the grease is there for a reason. I agree that a lot of it is useless but flushing the area with water and APC's can make your door hinges wear out quickly. Initially a shop towel works wonders and wipes off the excess while leaving the grease that's doing the lubricating in place. You really shouldn't need anything else other than a clean shop rag (old sock, cut up worn out T-Shirt) paper towel, blue paper shop towel, to wipe off the grease. From there just some cleaner wax wiped off with a rag again does a great job of cleaning the area without stripping the lubricant from your hinges.
Steam works best on filthy door jambs, I have a small detail brush that I also use, after I clean it I then use compressed air to blow all of the dirt and water away before it dries on me then wipe using a MF towel.
By cheekyage in forum Auto Detailing 101
Last Post: 07-30-2017, 06:51 PM
Last Post: 04-13-2016, 07:43 AM
By 99monguse in forum Tricks, Tips and Techniques
Last Post: 09-23-2015, 12:34 PM
By fellipe in forum Auto Detailing 101
Last Post: 09-02-2014, 09:15 AM
Last Post: 09-12-2011, 08:43 AM
