removing spider webs from the plexiglass?
Hello, i would like to remove these tiny spider web scratches from my pc plexi panel and am thinking of buying meguiars plastx.Will the plastx able to remove these?
Re: removing spider webs from the plexiglass?
Originally Posted by ozzy1925
Hello, i would like to remove these tiny spider web from my pc plexi panel and am thinking of buying meguiars plastx.Will the plastx able to remove these?
If they are just spiderwebs why don't you just use a damp sponge to remove them?
Okay, bad joke
PlastX by itself (applying by hand) will greatly reduce your spiderwebs. If you want even better results try using foam pads and a DA or Drill with your PlastX. You could also wet sand and then polish
What is that, a screen door?
Okay, bad joke
Never had experience with drill or wet sand and i am thinking of applying by hand with this:
http://www.meguiars.com/en/automotiv...pplicator-pad/
is that ok or should i apply with micro fiber towel?
btw, its pc case side panel
Hello
PC as is Personal Computer?
I have never used plastx.
But wet sanding might be to extreme. If your going to use a drill I'd imagine this would work
http://youtu.be/T0Uyj_NcKBo
Good luck and just trying to help.
Originally Posted by hernandez.art13
yea pc as personal computer.Getting a drill and da tool will cost me a lot in my country so only option for me is using meguiars foam applicator or microfiber towel with plastx.Which will be better ?
Not sure which foam applicator you mean. However, I am pretty sure the pads shown in the video ^ would be able to be done by hand.
At the shop we sometimes to buff out small areas by hand and a MF towel as well. About 1"x1" section (give or take)
this
i am talking about this pad:
http://www.meguiars.com/en/automotiv...d-(pack-of-4)/
i will apply the plastx with this pad and then finish with microfiber towel is that ok?
or i see it says gentler than foam pad:
http://www.meguiars.com/en/automotiv...plicator-pads/
what you think?
sorry they are not showing up on my phone
This is all I see,
This is all I see,
ah, let me upload the pictures for you here then
I've never used the 3rd picture, the even coat. The other 2 seem more for application.
These seem like they would be more designated for the job.
http://www.autogeek.net/hydro-3-pack.html
Or this and some 3" pads?
http://www.autogeek.net/s3hp.html
By BLUEOVALFITTER in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-19-2019, 12:46 AM
By IAJack in forum Ask your detailing questions!
Last Post: 03-20-2018, 10:05 AM
By nickyd845 in forum Ask your detailing questions!
Last Post: 10-03-2017, 08:55 PM
By Gungho_15 in forum Auto Detailing 101
Last Post: 05-21-2008, 07:18 PM
By jfsully in forum Auto Detailing 101
Last Post: 04-12-2007, 03:22 PM
