Found new spray nozzle for washing...Need thoughts and opinions please
I bought this new car wash spray nozzle from walmart last week and it has about 6 different spray patterns with a clear plastic screw on type bottle for carwash solution that holds about 4oz of soap. Im new to using this thing and from the two times I already used it, it seemed to work alright. All I am doing with it is filling the canister with 2 oz of my carwash solution(Meguiars ultimate wash and wax), turn the dial on top to the soap option and with my spray pattern selected, I start spraying the car with the soap from top to bottom like if I were handwashing my car. Ill add more soap as needed...since it does run out fairly quick lol. What I want to know from my dear AGO friends, is do you think this is doing much good to actually washing the car, or is the 2 bucket method better and something I should go back to doing? Give me any thoughts you may have that could help me decide what to do. Thanks in advance
Re: Found new spray nozzle for washing...Need thoughts and opinions please
I dont think it could hurt. Adds a little more lubrication and will help break up grime before using the 2 bucket method
Jeremy Wayne
If you want to get super technical, its better to apply soap and chemicals with a foam cannon etc, from bottom to top. This helps avoid any possible runs and streaks that can (extremely rarely) cause stains in the paint.
Jeremy Wayne
Go buy the little big shot nozzle from Home Depot, 9 bucks, solid brass, made in usa. Basically you have a very hard spray without buying a power washer .Best 9 bucks I ever spent
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
I bought this same exact nozzle the OP has written about, but have yet to try it. I was thinking along the same lines. When it comes to car care products I am a bit impulsive. I'm sure one of these days I'll break it out, but since I discovered SnowSoap, I am considering a foam cannon the next time around.
2013 Nissan Sentra SL (Arctic White)
2013 Nissan Altima S (Metallic Grey)
2012 Toyota Corolla S 5 speed (White)
I have the same one. I use it to soak down the car before doing a 2 bucket wash.
I would not use this nozzle as a replacement to the 2 bucket method, but rather as a supplement.
how bout a pic of this thingamajig
Okay here it is =].
You don't think this would be useful on a professional level though? I know its a cheapy tool and all...I seen it one day in the detailing isle at walmart and thought maybe I should give it a go. Depending on how dirty the car is prior to washing, how affective do you think this would be trying to completely remove heavy rain water that's dried on the car, or even some road grime? I have an idea already what the answer may be.
By Route246 in forum Auto Detailing 101
Last Post: 04-22-2018, 11:39 AM
By gregory1420 in forum Auto Detailing 101
Last Post: 12-22-2017, 07:11 AM
By CEE DOG in forum Auto Detailing 101
Last Post: 12-24-2010, 07:33 PM
By cobraa in forum Auto Detailing 101
Last Post: 04-15-2010, 07:42 PM
By Surfer in forum Off-Topic
Last Post: 05-14-2007, 12:06 AM
