Results 1 to 7 of 7
    Jul 2012
    Connect foam gun to Pressure washer
    Hello all,
    I wanted to know if there is an adapter to connect my foam gun to my pressure washer.
    I bought the Wolfgang foam gun Wolfgang Quart Foamaster Foam Gun delivers a thick layer of foam to your vehicle to give the paint maximum lubrication as you wash. Enjoy a safer, it has a quick connect fitting to disconnect the gun handle. I tried to fit it into my pressure washer lance but the quick connect for the foam gun is too big to fit into the quick connect of the pressure washer. I have a Honda presure washer. Any ideas would be apperciated.
    Thanks
    Aug 2011
    Re: Connect foam gun to Pressure washer
    That foam gun isn't meant to connect to a pressure washer. Only a hose.
    Regular Member storm100's Avatar
    Jan 2011
    Central Coast, CA
    197
    You want the foam cannon.
    Jul 2012
    Aw man I don't feel like spending $100 for a canon. Going to see if I can find somesort of adapter. Or maybe I can use the resvoir my pressure washer has and just put in my foaming soap there. I have a Honda homelite washer
    Honda 2700 psi 2.4 GPM Gas Pressure Washer-UT80993A at The Home Depot
    Think it would work?
    Super Member rwisejr's Avatar
    Apr 2007
    LI NY
    1,099
    Well you can get this from Home Depot . Not as good as a cannon but shout do what you want . G-Foam Blaster for 4,000 psi Pressure Washers-AGPWF04 at The Home Depot
    Ron !!!!!
    Jul 2012
    thanks. think i'll give that a try.
    Apr 2007
    LI NY
    1,099
    For the price you can't go wrong. But you don't have the adjustements of a true cannon. But it should work for you well enough.
    Ron !!!!!
  1. Change quick connect for pressure washer foam cannon?
    By gupster88 in forum Auto Detailing 101
    Last Post: 10-06-2017, 06:45 AM
  2. Pressure washer quick connect
    By Alienstudio in forum Auto Detailing 101
    Last Post: 08-08-2016, 07:49 PM
  3. How do I connect a foam gun to my Simoniz pressure washer?
    By I an in forum Auto Detailing Tools and Accessories
    Last Post: 07-22-2016, 09:28 PM
  4. How do i connect foam cannon to a pressure washer?
    By kaboose786 in forum Auto Detailing 101
    Last Post: 06-26-2012, 09:52 PM
  5. pressure washer quick connect for foam cannon
    By canuckian in forum Auto Detailing Tools and Accessories
    Last Post: 10-18-2010, 05:48 PM
