Results 1 to 7 of 7
    Super Member StephenK's Avatar
    Jul 2006
    Rochelle, Illinois
    1,589
    another clear coat question
    i got a H2 coming in next week and was wondering how is the clear coat on these?
    my first thought was going with OPT spray compound/polish with LC orange pad on PC. then i thought how big is it and may end up using DeWalt 849. is the 849 overkill?
    Aug 2011
    The "OC"
    895
    Re: another clear coat question
    I don't remember the paint being overly soft or hard, but the H2 is a ton of work not only from size, but the height and odd panels. I ended up using the PC with a 4" pad a lot, kind of ironic considering the size of the vehicle.
    If the paint is bad, I would correct the bulk of it via rotary and finish with the DA.
    There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
    Jul 2006
    Rochelle, Illinois
    1,589
    Quote Originally Posted by SonOfOC View Post
    thats another way i was thinking of doing it to. right now the customer is debateing between a 1 step or 2 step. and of course it is black
    Super Member shoeless89's Avatar
    Jul 2010
    Union, KY
    1,985
    Good luck on a car that big! Even if I just did a 1 step it would probably take me 2 days by the time I washed it, clayed it, taped off everything and polished then sealed it. I can for sure see how 4" pads will come it handy A LOT!
    Rule 62: Don't take yourself to d*mn seriously
    Cincinnati, OH
    Shawn
    Apr 2009
    OHIO
    253
    If your experienced with a rotary I would go that route.
    I have polished out black vehicles with a 50/50 wool pad with a quality all in one polish with total paint correction and when looked over outside in the direct light, not a swirl to be seen.
    With a little practice 50/50 wool pads save alot of time and with perfect results.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,099
    Is that purple foam wool or a blended wool?
    Quote Originally Posted by SuperGlide View Post
    Apr 2009
    OHIO
    253
    Blended Wool
  1. Clear Coat Question for the pro’s
    By bigmackmiller in forum Auto Detailing 101
    Last Post: 12-01-2018, 07:48 PM
  2. clear coat question
    By Tragu in forum Auto Detailing 101
    Last Post: 10-03-2007, 08:30 AM
  3. question about clear coat
    Last Post: 09-14-2007, 02:38 PM
  4. clear coat question
    Last Post: 07-03-2007, 09:35 PM
  5. clear coat and the PC....question/help
    By JGS93GT in forum Auto Detailing 101
    Last Post: 06-05-2007, 07:38 PM
