Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Aug 2010
    New Jersey
    15,167
    Re: How do you stay away from holograms?
    Sounds like you probably have some polish residue, either oils or dried product.
  2. #32
    Newbie Member marsomthing's Avatar
    Nov 2011
    Quote Originally Posted by 5.4 Shelby View Post
    Something else I thought of during the night. Did you clean and clay the car real well? That part of the car is usually very dirty and gritty. I wonder if you picked up a contaminate from behind the front tires and marred your door with it? Be sure to inspect your pads for grit. You might try going back over it with clay before repolishing.
    I did not clay it right before but I keep it very clean and smooth(imo). what does it mean to mar the paint? Smear contaminates around your clear coat via buffer?
    BTW thanks for all the help to a new guy like me!
  3. #33
    Super Member 5.4 Shelby's Avatar
    Feb 2010
    970
    Quote Originally Posted by marsomthing View Post
    Marring is basically fine scratches in the paint instilled by yourself. Rubbing too hard with paint clay, polishing with a dirty pad, working the polish dry, etc. Compounds, such as M105, UC and D300 will often mar the paint at a very fine level. That is why it is usually necessary to go to a polishing step, such as M205, UP or D301. On dark colors and/or soft paint, you may need to even go to a finishing step like Menzerna PO85rd on a gray pad to get all the marring out.
    Dont get too worked up about this. No one starts out perfect. As with anything, it takes pratice and experience to refine your technique. Spend plenty of time practicing on your own vehicles and reading this forum. I had about 8 or 9 years of experience with DA polishers when I found this site 2 years ago. I have gained more in the last 2 years than I did in the first 9 just by reading and discussing on here. There a plenty of good people willing to help you get this figured out. You might even find a local willing to show you some tricks.
    Kevin
  4. #34
    Nov 2011
    After polishing again I noticed it seemed to appear oil like...so I went ahead and just finished it with some wax and it took away the Smear/string/hologram left over.
    So I am one happy camper, swirl free in the sun too!!!
  5. #35
    Feb 2010
    970
    Glad you are happy.
    In the future, try wiping the panel down after polishing with isopropyl alcohol solution. It will remove the oils. If swirls re-appear after that step, it means the oils were hiding them.
    I still think you are working too long or using too much polish or something. Normally the oils will wipe clean. try changing the pad, use less polish and/or clean the pad "on the fly". Might also try changing your polish removal towel more often.
    Kevin
  6. #36
    Nov 2011
    Thanks for the help, I used less on the rest of the car, and it seemed to do the job!!!
    once again thanks for the help!!!!!!!!!!!!!
  7. #37
    Feb 2010
    970
    No problem. That is why we are here. Someday you can pass the info you learn on to a new guy when he needs help.
    Kevin
  1. Where to stay?
    By frankprozzoly in forum 2015 Autogeek Detailfest
    Last Post: 02-10-2015, 11:17 PM
  2. Stay Fresh Car Care
    Last Post: 06-09-2014, 12:11 AM
  3. How to stay cool.
    By Harleyguy in forum Off-Topic
    Last Post: 06-26-2010, 04:56 PM
  4. How long does wax stay on
    By tnbug4me in forum Auto Detailing 101
    Last Post: 08-10-2008, 09:49 PM
  5. Why detailers stay busy!
    By shadybreal in forum Show N' Shine
    Last Post: 03-31-2007, 01:51 PM
