Results 21 to 30 of 37
  1. #21
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Re: How do you stay away from holograms?
    Quote Originally Posted by 5.4 Shelby View Post
    I dont use a rotary, but, I would think using one for wax application is kinda like using a chainsaw to trim the grass on your sidewalk.
    Great Analysis
  2. #22
    Newbie Member marsomthing's Avatar
    Nov 2011
    holograms are from using a rotary polisher. Not a DA. If you have ever seen one of those poorly polished black cars that lok like they have comet trails all over the paint, those are holograms. Once you have seen them, there is no mistaking what they are. Start looking at the paint on every car you see on the road (all geeks do that anyway).
    Everything I have read said the same thing, but I just used a DA (w/ MG ultimate compund & ultimate polish, I have not gotten into the professional line yet) and I have crazy vertical holograms going up and down the door....so what did i do wrong with my DA? Its a giots I used white CCS pads for both steps, would a softer pad same product work to eliminate them?
  3. #23
    Super Member 5.4 Shelby's Avatar
    Feb 2010
    970
    Quote Originally Posted by marsomthing View Post
    Do you have pics?
    At first guess I would think you may be working it too long and therefore working it dry. The products you are using and the pad are appropriate. White pads should be somewhat gentle.
    Also, try cleaning the panel with IPA or MS or Dawn wash. Maybe you are seeing polishing oils that you did not get all the way off.
    Pics would be very helpful.
    Kevin
  4. #24
    Nov 2011
    If I can tomorrow I will break out the camera, I got out all the swirls I was trying to but took it out in the sun and saw them...
    If I worked a product to much would that explain all the "dust" blown bits left above my door? Would less section passes work?
    Speaking of product... I have always used the line Autozone etc carries( I guess its the general market easy use line)
    ...how much better is this numbered line Meguiers makes (#80, 105, 205) Are they kind of like a more expierenced persons line? or just something like a step above the line major stores carry.
  5. #25
    Nov 2011
    Do you have pics?
    here is a crappy picture...in the sun these streaks/holograms are all over....
    Attached Thumbnails Attached Thumbnails How do you stay away from holograms?-imag0499-jpg
  6. #26
    Feb 2010
    970
    I would give UC a very high grade. Easier to work with then 105. Doesnt cut quite as fast.
    Havent used UP. I have used SwirlX which is similar and a fine product.
    Hard to tell from that pic. Try hitting again with UP on clean pad. Work less passes. Only 3 or 4 section passes. With SMAT products you dont have to work until broken down. Clean with IPA (isopropyl alcohol) when done to ensure oils are removed. Re-evaluate paint to see if removed.
    Kevin
  7. #27
    Feb 2010
    970
    Something else I thought of during the night. Did you clean and clay the car real well? That part of the car is usually very dirty and gritty. I wonder if you picked up a contaminate from behind the front tires and marred your door with it? Be sure to inspect your pads for grit. You might try going back over it with clay before repolishing.
    Kevin
  8. #28
    Feb 2010
    970
    Kevin
  9. #29
    Aug 2010
    New Jersey
    15,170
    That doesn't look like holograms to me. How many passes with your DA and UC did you do? Did you use the rotary on it beforehand? Was there any wetsanding involved?
  10. #30
    Nov 2011
    I did around 4-6 passes. i did not use a rotary or wet sanding. I used a griots polisher speed 5. LIke I said before my goal was to remove the swirls which I dida good job...Ill try some of the suggestions and see what happens.
  1. Where to stay?
    By frankprozzoly in forum 2015 Autogeek Detailfest
    Last Post: 02-10-2015, 11:17 PM
  2. Stay Fresh Car Care
    Last Post: 06-09-2014, 12:11 AM
  3. How to stay cool.
    By Harleyguy in forum Off-Topic
    Last Post: 06-26-2010, 04:56 PM
  4. How long does wax stay on
    By tnbug4me in forum Auto Detailing 101
    Last Post: 08-10-2008, 09:49 PM
  5. Why detailers stay busy!
    By shadybreal in forum Show N' Shine
    Last Post: 03-31-2007, 01:51 PM
