Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Junior Member Street Rat's Avatar
    Join Date
    Aug 2010
    Location
    Georgetown, Texas
    Posts
    49
    Post Thanks / Like
    Anti Static Detailers
    I just buffed and waxed my black '81 Corvette. The thing is a dust magnet now.
    What is your recommendation on an anti static spray detailer?
    Craig
  2. #2
    Super Member rlmccarty2000's Avatar
    Join Date
    Dec 2013
    Location
    Fitzgerald, GA
    Posts
    2,002
    Post Thanks / Like
    Re: Anti Static Detailers
    Kenotek Showroom Shine touts their QD as an anti-static product. I’ve used it and like it, but not sure of its anti-static properties. Someone here (I think) suggested grounding your car to cut down on static. Also wax seems to attract more dust than a sealant or coating.
  3. #3
    Super Member
    Join Date
    Feb 2017
    Posts
    212
    Post Thanks / Like
    I too thought of suggesting the grounding technique, but in this case its a Corvette with a fiberglass body, Not sure if that would work.
    There are a few QDs that advertise anti-static properties though.
  4. #4
    Mike Phillips
    Guest
    I wish I had a quarter for every time I share the below....
    Water turns a surface anti-static - BUT only temporarily.
    Your car's paint HAS it's own static charge, remove the paint remove the paint's charge. Now the underlying body panels have their own static charge, remove the body panels, remove the static charge... whoops! Can't do that, won't have a car. The dust accumulating on your car's paint has a static charge, going to be kind of hard to remove all the dust circulating around Planet Earth.
    So there's no actual solution. ANY spray detailer or at least any spray detailer that contains water will temporarily remove "some" of the built-up static charge from the surface of your car and make it less of a dust magenet.
    Also just to note, whenever we WIPE the surface of our car and the paint that's on it, WE create the static charge, have you ever rubbed a ballon over the hair on your head as a kid and via static made your hair stand on end?
    Here's my article from 2010
    Static Electricity and Dust Attraction to your Car's Paint
    So pick your favorite water based spray detailer and carefully wipe your car's finish.
  5. #5
    Mike Phillips
    Guest
    There used to be a product on the market called
    Meguiar's Medallion Paint Protection
    It used a cationic chemical/electrical action to "help" turn the surface anti-static. All the molecules in the product were positive while all the molecules in your car's paint are negative, somehow opposites attract and somehow the surface would be protected and have less static charge.
    I have a couple bottles in my antique car wax collection and also all the old catalogs that share info about the product.
    It's long gone....
    I use a lot of it on show cars, thought it worked very well. Back when it was around it was $20.00 a bottle and most people choked up blood when they found out how much it cost.
  6. #6
    Super Member camaro2ssblack's Avatar
    Join Date
    Nov 2012
    Location
    Jackson, TN
    Posts
    443
    Post Thanks / Like
    This is why I stopped using paste waxes, attracts dust like crazy in my experience.
  7. #7
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,827
    Post Thanks / Like
    I've used Kenotek Showroom Shine for some time and while it is a great QD spray, I too don't think I'd call it "anti-static" or static defeating. However, it does leave the surface slicker than any other QD I've used, and I did notice after doing a wipe down vehicles wouldn't collect dust or pollen quite as quickly. The slickness of the product may be at work in that regard.
    Drop by to see the latest at The Car Geek Blog
  8. #8
    Super Member acuRAS82's Avatar
    Join Date
    May 2017
    Location
    Pittsburgh PA
    Posts
    2,847
    Post Thanks / Like
    FK215, Ultima QD and UWW+ and Ultima Acrylic WW and Pinnacle WW (which contains carnauba) are all said to have anti-static properties.
    I will say that I topped both my cars with Souveran recently and use Pinnacle WW for light cleaning and I’ve been very happy with the lack of dust/dirt buildup over the past few weeks. Granted, it’s not pollen season here in SW PA.
  9. #9
    Super Member Coach Steve's Avatar
    Join Date
    Jun 2013
    Location
    Chandler, AZ
    Posts
    410
    Post Thanks / Like
    When I was a kid, I remember my mom lightly spraying Endust on a feather-type duster to dust around the knick-knacks, and figurines in her display case. The Endust charged the feather duster somehow and the dust would jump onto it as she would move it around the shelves. It allowed her to dust without having to move each item. It worked very well - almost like magic how the dust would literally jump onto the duster like metal shavings being drawn to a strong magnet.
    When I first started detailing and ran into the issue with the vehicle attracting dust, I wished there was a product that incorporated whatever ingredient was in Endust that created a stronger attractant for the dust.
    I'm sure it's some sort of patented secret and not suitable for use on vehicles.
  10. #10
    Super Member
    Join Date
    Jun 2014
    Location
    Chandler, AZ
    Posts
    3,360
    Post Thanks / Like
    If you live in an extra dusty environment, such as a dry desert, carinuba wax will act like a dust magnet. This is one reason I switched to using ceramic coatings and their specific maintenance sprays such as ReLoad and for QD/Waterless wash, Ech2o. You’d be surprised at the lack of dust.
    Please excuse the typos. Sent from my iPhone using Tapatalk
Similar Threads
  1. Anti-static, gimmick or real?
    By ArkayoDeetayo in forum Off-Topic
    Last Post: 03-06-2012, 04:03 AM
  2. Anti-Static QD?
    By big tyme in forum Auto Detailing 101
    Last Post: 09-12-2011, 09:29 AM
  3. Anti-Static Products?
    By IID in forum Ask your detailing questions!
    Last Post: 10-05-2010, 08:37 PM
  4. Anti Static Products?
    By FMINUS in forum Auto Detailing 101
    Last Post: 07-08-2008, 11:49 AM
  5. ANTI STATIC QDer's......
    By BILL in forum Auto Detailing 101
    Last Post: 08-01-2007, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
