Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Nov 2016
    KY
    1,065
    Re: Foam Cannon Question
    no filter. a foaming screen.
    Kirk Harrod's Mobile Detailing, Frankfort, KY
    Official Detailer of Camarofest 8 & 9
    No one has detailed more Camaros.
    May 2015
    83
    The screen definitely can be clogged up by failure to clean after use.
    Here is what it looks like. Not a bad idea to have some spares.
    Foam Cannon HP Pressed Strainer 3-Pack, foam cannon replacement parts
  3. #13
    Super Member sweatthedetails's Avatar
    May 2012
    Semmes, AL
    483
    The filter looked pretty good. I don't use the cannon very often, only when I mobile and want to get noticed Foam Cannon Question. I put it back together and it now seems to work fine. I think when I dropped it I may have moved it inside the housing.
  4. #14
    Nov 2016
    KY
    1,065
    You cant really look at at the screen and tell its clogged. The CLR probably cleared it. Just run a bottle of clean water thru it after you are done foaming. I use it to rinse the last car I foam.
  5. #15
    May 2015
    83
    Thank you for the update. Glad the canon is back in service.
  1. Foam Cannon Question!
    By Hammer77 in forum Tricks, Tips and Techniques
    Last Post: 03-09-2016, 10:00 PM
  2. Foam Cannon question
    By j2thad2thac in forum Hot topics & Frequently Asked Questions
    Last Post: 02-02-2016, 03:47 AM
  3. Foam Cannon Question
    By Paul_no_Longer_uses_this_account in forum Auto Detailing Tools and Accessories
    Last Post: 07-29-2012, 08:40 AM
  4. Foam Cannon Question
    By RSVCHAD in forum Auto Detailing 101
    Last Post: 05-05-2011, 02:58 AM
  5. Question about the Foam Cannon?
    By bimmer325! in forum Auto Detailing 101
    Last Post: 07-07-2010, 11:36 PM
