Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Gyeon Q2 Primer
  1. #21
    SELF BANNED
    Jun 2019
    1,076
    Re: Gyeon Q2 Primer
    Quote Originally Posted by TTQ B4U View Post
    Just use GYEON Primer. It removes swirls and acts as a good one-step. Doubtful you'll need to compound unless it's trashed. Primer makes application of their coatings easier too.
    I agree primer makes the paint very smooth! I will be using primer this year just so i'm sure i will have a great bond and like you said it makes the application much more enjoyable. And i really enjoy working with primer.
    Going to polish with a medium compound and pad first and quickly finish with primer and a finishing pad.
    Rupes yellow foam and white, LC orange SDO and buff and shine red uro-cell - maybe uro-fiber 50/50 if I need it. First step - leale, 3D one or rupes DA fine - all 3 have different cutting abilities according to the manufacturers.
    I will have all them on my detailing cart.
    Actually thinking i will pick up my 2nd bottle of perfect finish and call it a day but i really don't like wasting money...only on beer haha
  2. #22
    May 2013
    TN
    1,768
    Re: Gyeon Q2 Primer
    I’m planning to use CanCoat Evo soon and I looked at using Primer as a final polish before application. I found it stated a couple places including Autogeek (last paragraph) that if you don’t want to do an IPA/prep wipe prior to coating, that you must wait 24 hours after using Primer before you can coat.
  3. #23
    SELF BANNED
    Jun 2019
    1,076
    Re: Gyeon Q2 Primer
    Quote Originally Posted by dgage View Post
    What's the hurry? lol I've been told by an industry guy that 4-6 hours is fine to apply cancoat over primer without an IPA.
    I have never tried it.
    I will be applying cancoat late this summer i think. Applying high solid coatings outside is very tricky. I just want it to last 8mths or so.
  4. #24
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Re: Gyeon Q2 Primer
    A panel wipe can be done as soon as one is done polishing. There are no I’ll effects doing so.
  5. Thanks CleanIT thanked for this post
  6. #25
    May 2013
    TN
    1,768
    Re: Gyeon Q2 Primer
    I understand. What I’m trying to point out to people, similar to the confusion with Essence is that it can’t just be coated afterwards WITHOUT a panel wipe unless proper cure time for Primer is given. At least that is what I’ve read multiple places. So for those in more of a hurry, a panel wipe seems to be required for Primer before coating.
  7. Likes CleanIT liked this post
  8. #26
    Dec 2011
    Pompano Beach, Fl
    1,494
    Re: Gyeon Q2 Primer
    On lake country I use blue, green or black… And don’t Make the mistake that many people do on using a polisher; they move it too fast. On a 2 x 2 section make sure it’s taking you up to at least 4 Mississippi’s to move across the block… Let the polisher do the work. Too many people use it like they’re painting the surface.
    Glen -
  9. Thanks CleanIT thanked for this post
  10. #27
    Super Member CleanIT's Avatar
    Aug 2019
    1,832
    Re: Gyeon Q2 Primer
    I used Primer and followed up with Paint Prep after I was done. I didn't wait 24 hours. Primer was on the paint for at most 30 mins before I removed it with Paint Prep. Not ideal but I was cut for time. I thought Primer worked well.
  11. Likes dgage liked this post
  12. #28
    Aug 2019
    1,832
    Re: Gyeon Q2 Primer
    Quote Originally Posted by glen e View Post
    That's why I still have some swirl marks. I was doing it outside on my only day off battling the sun, so I did it too quickly. I'm happy with how it came out but it could have been much better. Come fall I will do it much more slowly and put Evo on it.
  13. #29
    Jun 2013
    LA, CA
    8,719
    Re: Gyeon Q2 Primer
    Quote Originally Posted by NJNinja View Post
    Come fall I want to re-polish and apply CC Evo. Is there a one step compound/polish I could use that would eliminate swirls that I could use to avoid using a compound and polish? Do you have to use Primer before applying CC?
    Primer is not a requirement to apply a coating. This goes for any primer polish. They have a light cut as they are finishing polishes.
    Unlike the Dr. Beasley’s surface primers which are a range of polishes.
    Dr. Beasley’s surface primers require no panel wipe and can be coated right over. In my experience these are better primers than Essence and Q2 Primer.
  14. Thanks CleanIT thanked for this post
    Likes dgage, CleanIT, TTQ B4U liked this post
  1. 2 step correction - 3D One x2 or 3D One + Gyeon Primer?
    By noorth in forum Auto Detailing 101
    Last Post: 09-02-2020, 07:36 AM
  2. Replies: 35
    Last Post: 04-28-2020, 09:03 AM
  3. Gyeon Primer vs Polish
    By Koogs in forum GYEON Car Care Products
    Last Post: 09-04-2018, 10:21 AM
  4. Gyeon primer vs carpros essence
    Last Post: 05-03-2017, 08:01 AM
  5. Replies: 14
    Last Post: 07-31-2014, 06:32 AM
