Coating gelcoat
How will GYEON Syncro do on gelcoat? I assume it’ll work about the as on a cars paint. Also, what is the minimum temperature Syncro could be applied?
Re: Coating gelcoat
Good Afternoon!
SYNCRO will perform fine over gelcoat. I would expect to use bit more Mohs than you would an automotive paint as the gelcoat will absorb more, but no issues other than that.
Minimum temperature would be around 55-60 degrees F. The real issue is that it will take much longer for the coating to flash and be ready for wipe off at the low temperature. Enjoy!
Last Post: 11-17-2020, 09:06 PM
Last Post: 10-27-2020, 09:15 AM
By Mike Phillips in forum PICTURES: 2-Day BOAT Detailing Classes
Last Post: 11-26-2018, 12:00 PM
By Misael7 in forum Auto Detailing 101
Last Post: 09-17-2014, 03:50 PM
By NY-Bondo in forum Products Guides
Last Post: 01-13-2013, 11:09 AM
