Re: Griots machine polish help
Try those two things and let us know if it helps. Make sure you don't overload the pad. Over saturation will just generate more heat.
Ok. I'll try everything you mentioned. How is Meg's 105? I can get 105 and 205 OTC here so it would be convenient. I can always save the griots for the "winter" months here. I have a car to do next weekend that I will have access to a garage and adequate lighting so I will be sure to update my situation then. I appreciate all the help
I used 105 as an example of a compound that I had to add small sprays of water to while using. It's actually one of the worst as far as drying out/dusting. I haven't heard much about 205 dusting.
The Optimum Hyper Ploish and Hyper Compound have good long work times. Also the Menzerna line FG400-compound and ff4000-polish. Menzerna changed their numbering system I think th 4000 is now 3500, not sure what the 400 is. With the Menzerna line they seem to use more polishing oils so wipe off is a little more work. I know they aren't local, but I would recommend the Hyper Polish and Compound. Both very versatile products. Hyper Polish was one of the first polishes I ever ordered and even after the 10 or 12 others I've purchased I still use this one as much or more than any other. They are very user friendly and the amount of cut depends a lot on the pad you use. You should still have time to get them from AG. I would call them and let them know you need them by the weekend and maybe ask them to send them FedEx. I usually have product from Florida in three days from FedEx vs 5 with UPS.
By Mike Phillips in forum Show N' Shine
Last Post: 05-04-2016, 07:27 AM
By Mnlc90 in forum Auto Detailing 101
Last Post: 01-22-2014, 10:06 PM
By stangfreak in forum Products Guides
Last Post: 10-04-2012, 05:17 PM
By CEE DOG in forum Product Reviews
Last Post: 06-14-2011, 10:28 PM
By CEE DOG in forum Auto Detailing 101
Last Post: 11-15-2009, 10:38 PM
