Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 81 to 90 of 131
  1. #81
    Apr 2015
    PGH, PA
    1,482
    Re: Griot's Garage G15/G21 Long-Throw Orbital Polisher *Ground-Up Redesign*
    Simple fix, just go back to the old backing plate..or get a Makita PO5000C plate
    Hopefully the LC UDOS plate doesn't have the same outcome
  2. #82
    Regular Member Epilogts's Avatar
    Jan 2020
    Boulder, CO
    168
    Quote Originally Posted by Mike@ShineStruck View Post
    Simple fix, just go back to the old backing plate..or get a Makita PO5000C plate Hopefully the LC UDOS plate doesn't have the same outcome
    Aside from the integrated backing plate cooling...
    “Due to its long-throw articulation, the G21 could not integrate fan cooling in its counterbalance like the G9. So we engineered the G21 with its cooling fan integrated into the backing plate. This new backing plate technology was developed exclusively for these machines and is undeniably best in class.”
  3. #83
    Apr 2015
    PGH, PA
    1,482
    Quote Originally Posted by Epilogts View Post
    Just switch out your pads more often
    l typically do every panel or two anyways
    If the machine get unusablly hot due to a backing plate, then Griot dropped the ball on design and should of did more than just bandaid it with a fanned BP
    If the UDOS plate is shipping, that'd be a better route though..but it's probably still Preorder
  4. #84
    Jan 2020
    Boulder, CO
    168
    I assume it’s for machine cooling and swapping pads probably won’t make a big difference, other than letting it cool while you swap. Although, the backing plate breakage could be due to plastic fatigue due to heat? But I’m not a materials expert...
  5. #85
    Apr 2015
    PGH, PA
    1,482
    Yes it's for machine Cooling, I'm just not sure how much the fan actually cools vs a regular vented plate...
    neither has the shroud sealed by the plate like a factory Rupes... I'm just assuming the heat difference would be negliable...but reality is.. I think they band aided an issue and it wasn't enough..causing material to break down and fail
  6. #86
    Apr 2015
    PGH, PA
    1,482
    Old Griot boss plates won't work though, needs the updated mark II style like makitas
  7. #87
    Nov 2009
    Pasadena, CA
    12,615
    You can’t just go putting on any backing plate. Weight plays an important role. Use the manufacturers backing plate.
    '03 Corvette Z06
  8. #88
    Apr 2015
    PGH, PA
    1,482
    It does, as do pad weights...
    You can compensate with a different weight pad if it did infact induce imbalance
  9. #89
    May 2020
    Does anyone have a clue with what is going on at Griot's regarding their two long-throw machines? Have they been available, but then quickly sold out? Or, has production simply delayed the actual release?
    If some have actually been sold and are being used....what is the consensus of them?
  10. #90
    Mar 2017
    Southeastern PA
    2,482
    They shipped some of the new G21 but i think that is halted due to people having backing plate issues. While they try to address that issue, nothing is shipping, neither G15 nor G21. I believe the G15 hasn’t been shipped at all in this new version.
    Some of the feedback was that the new G21 is hotter and due to being taller felt a little less balanced. There aren’t many reviews out there though so we have to wait more.
    I’m sure Griot’s will make it right, if you have some time and can wait.
    Bruno Soares
  1. Griot's Garage LIVE: G15/21 Long Throw Orbital (2020)
    By VISITOR in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 09-24-2020, 09:02 PM
  2. Griots Garage BOSS G15/G21 Long-Throw Orbital Polisher Free Bonus! **LIMITED TIME PROMOTION**
    Last Post: 06-14-2018, 11:29 PM
  3. Replies: 85
    Last Post: 04-26-2017, 07:16 AM
  4. Long throw orbital polisher
    By LSNAutoDetailing in forum Auto Detailing 101
    Last Post: 06-08-2015, 08:33 PM
  5. Griot's Garage Random Orbital 3' Polisher as primary polisher
    By torque1989 in forum Ask your detailing questions!
    Last Post: 07-01-2011, 10:11 AM
Members who have read this thread: 5
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
