Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 69
  1. #41
    Super Member Rsurfer's Avatar
    Jan 2007
    14,096
    Re: And then... There was a G8 (Polisher)
    Quote Originally Posted by troda View Post
    lol. Maybe golf.
  2. #42
    Jan 2020
    Quote Originally Posted by Troda View Post
    I unfortunately drew short straw. Mine arrived the other day. I spun it up with no load and the speed would oscillate. I switched cord but made no difference. It’s mist prevalent at speed 3 where you can hear feel a slight bump. It does all the same stuff loaded as well. Going to try and swap out the brushes. If that doesn’t work it’s back to griots.
    In the recent past I’ve had a failed G9, a failed Adams SK micro, a broken shelf on my detail cart and now this. Can only go up from here.
    My G8 had the same problems. The speed oscillated up and down fairly dramatically on speeds 1-3. It sounded like an engine trying to rev up but not quite getting there, as if the power was intermittent. There also was a bump on speeds 2 and 3 that you could feel and hear. I called Griot's, and they're exchanging the polisher for a new one.
  3. #43
    Jul 2013
    Apex, NC
    1,283
    Make sure that the cord is pushed in all the way. There are people finding out that it takes more force than what they thought for the cord to fully seat.
  4. #44
    Jan 2020
    Quote Originally Posted by DBAILEY View Post
    I had it in until it clicked, and I also tried the cord from my G9. The performance was the same with both cords pushed all the way in.
  5. Likes DBAILEY liked this post
  6. #45
    Aug 2015
    Andover, MN
    1,727
    Just curious - The speed fluctuation is while polishing, or only with it unloaded in the air?
    If only in the air I wonder if it's the digital speed controller trying to regulate RPM when it's expecting to need to overcome pad pressure.
    It's been a couple months since I touched my G9 so I don't remember exactly what it was, but I remember the experience of cleaning pads via pad brush was different with the G9 than the GG6.
  7. #46
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Quote Originally Posted by oneheadlite View Post
    That's a good point you bring up, the tool running under load, versus no load?
    Not sure what is incorporated inside these new 2 new machines from Griots, and whether they use such digital controllers as you say?
    Does their manuals state such?
  8. #47
    Mar 2017
    Southeastern PA
    2,480
    Quote Originally Posted by MarkD51 View Post
    Yes, they both have digital controllers that increase power as the machine detects resistance from the user applying more pressure. To keep pad spinning at the same speed the machine increases power without the need to adjust the dial.
    Bruno Soares
  9. Thanks oneheadlite thanked for this post
    Likes oneheadlite liked this post
  10. #48
    Jan 2020
    It happened in the air and then while polishing a test panel. The digital speed controller idea may be a possibility. The good news is that Griot's responded right away, and in exactly the way you'd expect them too. I saw enough to know that once the kinks are worked out, the G8 is going to be an amazing tool.
  11. #49
    Jan 2020
    Quote Originally Posted by KJack27 View Post
    Update: Griot's sent a replacement G8 and it works perfectly. None of the problems in the first one are present in this one.
  12. Thanks Diner thanked for this post
    Likes SWETM liked this post
  13. #50
    Oct 2019
    59
    Hmmm. I emailed 12/22 again 12/27 called 12/31 received email with call tag 1/3 . Received response to original email on 1/6 Sent email expressing displeasure. 1/7 received email stating holiday makes for delays, sorry.
  1. Replies: 9
    Last Post: 12-04-2019, 07:35 PM
  2. Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
    Last Post: 04-08-2018, 09:52 PM
  3. Replies: 0
    Last Post: 09-25-2017, 04:47 AM
  4. Replies: 0
    Last Post: 02-04-2016, 12:44 PM
  5. Griot's Garage Random Orbital 3' Polisher as primary polisher
    By torque1989 in forum Ask your detailing questions!
    Last Post: 07-01-2011, 10:11 AM
