Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 69
  1. #31
    Nov 2009
    Pasadena, CA
    12,615
    Re: And then... There was a G8 (Polisher)
    Got my G8. Very nice polisher. Smooth. Power is good on speed 5(mainly use). Speed 6 spins the pad very fast. Speed 4 is OK(stalls somewhat easy). Anything below that is useless. I love using the Rupes 3.75” and 2.5” foam pads. The Rupes wool pads would probably work nice, too. I used the G8 and G9 to correct my new ‘19 GT Mustang GT. It didn’t need anything aggressive. The G8 and G9 are very capable machines.
    '03 Corvette Z06
  2. Thanks oneheadlite, Diner, John U thanked for this post
  3. #32
    Thanks for the feedback about the tools Mark.
    :dblthubm2:
  4. Likes WRAPT C5Z06 liked this post
  5. #33
    Super Member rangerbay's Avatar
    Jun 2017
    Enterprise, Al.
    297
    I received my G8 last week. I've used it a few times, and it is fantastic. I have not found an issue with spinning at speed 3, but that is my polishing speed. I cut on 5 or 6, depending on the paint.
    The little G3 is still in my arsenal. I think it works fine with a 2" pad, just have to use full speed, and slow arm speed.
    My G9 is a beast! I haven't used a 15mm since I got the G9. The thing kicks ass!
    Bill
  6. Thanks Diner thanked for this post
    Likes VISITOR liked this post
  7. #34
    Oct 2019
    59
    I unfortunately drew short straw. Mine arrived the other day. I spun it up with no load and the speed would oscillate. I switched cord but made no difference. It’s mist prevalent at speed 3 where you can hear feel a slight bump. It does all the same stuff loaded as well. Going to try and swap out the brushes. If that doesn’t work it’s back to griots.
    In the recent past I’ve had a failed G9, a failed Adams SK micro, a broken shelf on my detail cart and now this. Can only go up from here.
  8. Thanks Diner thanked for this post
    Likes KBsToy liked this post
  9. #35
    Aug 2015
    Andover, MN
    1,727
    Troda - with a run like that, makes you wonder if you have a power (not cord) problem. Like something wrong on the service end so you’re getting dirty power supply.
  10. #36
    Oct 2019
    59
    This was in my house.200 amp service. Clean. G9 was at the shop. No issues with other polishers.
  11. #37
    Nov 2009
    Pasadena, CA
    12,615
    Quote Originally Posted by Troda View Post
    I noticed this today too!!! Feels as though the motor is skipping and bumping. Very prevalent. It does not do this on speed 4, 5, or 6. Only speeds 1-3. Calling Griots the next day they are open.
    '03 Corvette Z06
  12. #38
    Super Member JWilliams.RadiantDetail's Avatar
    May 2013
    710
    Quote Originally Posted by oneheadlite View Post
    The SK Micro's battery powered, and a broken shelf too. He's having a bad run of luck obviously. Hopefully this will get it all out of his system and 2020 will be better.
  13. Likes Troda liked this post
  14. #39
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Maybe you should take up fishing.
  15. Likes Troda, rangerbay liked this post
  16. #40
    Oct 2019
    59
    And then... There was a G8 (Polisher)-dfd1562a-a2b8-4e96-b329-f19d470fb756-jpg
  17. Likes rangerbay, Meghan, SWETM liked this post
  1. Replies: 9
    Last Post: 12-04-2019, 07:35 PM
  2. Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
    Last Post: 04-08-2018, 09:52 PM
  3. Replies: 0
    Last Post: 09-25-2017, 04:47 AM
  4. Replies: 0
    Last Post: 02-04-2016, 12:44 PM
  5. Griot's Garage Random Orbital 3' Polisher as primary polisher
    By torque1989 in forum Ask your detailing questions!
    Last Post: 07-01-2011, 10:11 AM
