Results 21 to 30 of 34
  1. #21
    Super Member Cruzscarwash's Avatar
    Oct 2015
    Desert of California
    2,425
    Re: For those who have upgraded to the BOSS
    Quote Originally Posted by ScottH View Post
    Is the brush issue only with the G21 or does it also apply to the G15? When you say wears out fast, what would you estimate that to be in hours of use?
    ScottH
    I've had to replace both my g15 and g21 since I've had them and the g15 is going back again. Idk what's wrong with them but it makes a grinding sound again
    Sent from my Pixel using Tapatalk
  2. #22
    Apr 2016
    65
    Hi ScottH,
    I bought mine around end of April. Replaced the brushes once around July. So I would say all depending on how many cars you will be doing. from end of April to July roughly 3 months past by and I had done 15 cars during the week-end only. So that roughly 14 week-ends at around 1 car per week-end. So you might say that the BOSS was being used quite often to full potential. I live in a very humid area in Canada (Ottawa/Gatineau). Our humidity factor has roughly an increase of 8-10 degrees.
  3. #23
    Nov 2015
    Los Angeles, California
    13,778
    What are the warning signs/symptoms that the brushes are starting to go out? And do you change them yourself, or do you send it in for repair?
  4. #24
    Oct 2015
    2,425
    A spare set should he in the red bag that was send with the box
  5. #25
    Nov 2015
    13,778
    Quote Originally Posted by Cruzscarwash View Post
    Yea I just checked to make sure I hadn't lost them... I have 2 sets of brushes, 4 washers, 1 extra backing plate screw, 3 tubes of silicone grease, and 1 allen wrench so I'm good.
    But that still doesn't answer my question, what are the early warning signs? And do you change out the brushes yourself, or is it something that requires the polisher to be sent back for them to do for you?
  6. #26
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    Yes it is something you can do yourself in less than 5 minutes. I used a small needle nosed plier to remove and install them. Check YouTube I am sure there must be a video. As far as warning signs, the Motor on mine had very little spin/power to it. So I unplugged it and changed the brushes and was 100% operational in a few mins. BTW this was on a GG6 but that doesn't matter - same process. Haven't had to change them on my G15 yet.
    ScottH
  7. Thanks Eldorado2k thanked for this post
  8. #27
    Apr 2016
    65
    Warning signs is that when you press the power button to turn the machine on sometimes it will power the machine sometimes it will not, or when you are working with the machine the power will skip.
    You can easily change the brushes yourself. You have 2 screws on each side of the machine. Just unscrew one at a time and replace the brushes. It's an in and out process.
  9. Thanks Eldorado2k thanked for this post
  10. #28
    Nov 2015
    13,778
    Quote Originally Posted by patricemougeot View Post
    I take it they'll both go out at the same time? Or is it just recommended to change them both just like I would spark plugs?
  11. #29
    Nov 2015
    Northern NJ
    895
    I don't know if they wear at the same exact rate but I would change they at the same time - that is what I did
    ScottH
  12. #30
    Nov 2015
    13,778
    ScottH
    Not a good time to turn into El Cheapo. For those who have upgraded to the BOSSlol.
  1. Sale has been upgraded to 25%
    By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 08-31-2018, 10:12 AM
  2. Detailing Class - Griot's BOSS System - Learn to detail like a BOSS!!!
    Last Post: 04-06-2018, 02:37 PM
  3. Upgraded Equipment
    By StrmChzr in forum Boat & Marine Craft Detailing
    Last Post: 05-15-2017, 10:05 AM
  4. Griot's 3" upgraded?
    Last Post: 03-23-2016, 05:10 PM
  5. Replies: 15
    Last Post: 08-04-2009, 07:38 AM
