Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: G21 rotation
    Super Member DETAILROOKIE's Avatar
    Jan 2016
    1,160
    G21 rotation
    Hello all,
    I hope everyone is enjoying their weekend!
    I received my BOSS 21 today and noticed that the backing plate does not spin freely, it will spin for a second and stop. Is this normal? I lubed the shroud, loosened the backing plate screw, did the washer mod with both washers, and changed the backing plate to the 5inch, and nothing worked. I did not have a pad on it, it was just the backing plate. This doesnt seem normal, but wanted to ask everyone and see if you have had similar experiences.
    Thank you for all of your help!
    Sent from my SAMSUNG-SM-G935A using Autogeekonline mobile app
    Super Member WaxMaster1's Avatar
    Jul 2015
    Central Florida
    1,261
    Re: G21 rotation
    I bought a G15 because it was a great deal. The washers that come with it are extremely thin. I went to the hardware store and got a thicker washer, (same one I put on my Rupes MKII) and modified it. No rubbing!
  3. Thanks kamir thanked for this post
    Likes kamir liked this post
  4. #3
    Jan 2016
    1,160
    Re: G21 rotation
    Thank you! I will pass by a hardware store and pick up a couple thicker washers.
    When I checked the backing plate after the washer mod, it did not look like it was rubbing the shroud, but still won't spin freely.
  5. #4
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Re: G21 rotation
    Like what Chris said, the 2 washers they sent isn't enough to space out the BP from the shroud. I complained to Griot's about it and they sent out extra washers for me. You need at least 3 to make it freely spin.
    Or you can make your own new washer like how Chris did it.
    Have you read my Griot's BOSS review?
  6. #5
    Jan 2016
    1,160
    Re: G21 rotation
    Gotcha! Since I did not see the shroud and backing plate rubbing at the edge, I thought there was something else going on.
    I will buy some thicker washers and try it out. Thank you !
  7. #6
    Nov 2015
    Los Angeles, California
    13,850
    G21 rotation
    You don't need extra washers... Actually adding more washers than needed could have a negative side effect which results in the center piece of the backing plate warping due to not being fully engaged during use.
    This is what started happening to mine with only 2 washers installed.
    Back to the washers... 2 washers gives plenty of clearance from the shroud. As long as you're sure it's not touching the shroud then it's not an issue, and adding more or thicker washers is not going to help the situation in any way.
    Use a flashlight to get a clear view of the clearance. 2 washers = more than enough clearance.
    As far as how many rotations you get on a free spin with the polisher? Mine was the same exact way when I got it new. It would only freely spin 1.5 maybe 2 times even with 2 washers installed. I haven't even bothered to check since.. It's a non factor.
  8. #7
    Nov 2009
    Pasadena, CA
    12,615
    G21 rotation
    Trim the shroud a bit. You want every bit of rotation you can get.
    '03 Corvette Z06
  9. #8
    Jan 2016
    1,160
    Re: G21 rotation
    As far as how many rotations you get on a free spins with the polisher? Mine was the same exact way when I got it new. It would only freely spin 1.5 maybe 2 times even with 2 washers installed. I haven't even bothered to check since.. It's a non factor.
    Thank you for your response!
    Mine looks exactly like yours does with the washer mod done. I actually did the same thing, used a flashlight to check the space, and it looked like there was plenty of space. I had the G15 and it spun freely, so I wasnt sure if it would affect its performace and reduce its correcting abilities.
  10. #9
    Nov 2015
    13,850
    Re: G21 rotation
    Quote Originally Posted by DETAILROOKIE View Post
    I was overthinking the exact same thing when I 1st got my polisher. I know how you feel right now and it's exciting to have your new polisher. It will work just fine. I actually use mine without the washers installed 99% of the time and it works great. I find it to run much smoother this way compared to with the washer[s] installed and still has plenty of power to knock through just about anything you'll encounter. [and if you run into a situation, the bag with the washers is always nearby]
  11. #10
    Jan 2016
    1,160
    Re: G21 rotation
    Thank you!
    Perhaps I should actually test out the machine on a panel before I start worrying about the free spinning. Lol
    I will buy some extra washers just incase and start experimenting to see what gives me the best results, I might prefer being washer free like yourself. Thanks again!
  1. Forced Rotation DA
    By Route246 in forum Auto Detailing 101
    Last Post: 02-10-2018, 09:22 PM
  2. More forced-rotation DA options...
    By roguegeek in forum Flex Polishers
    Last Post: 05-19-2015, 08:14 PM
  3. DA and Forced Rotation polishers
    By tedhw in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-04-2014, 08:30 PM
  4. How much pad rotation with a DA?
    By AV8R in forum Ask your detailing questions!
    Last Post: 04-30-2010, 06:25 PM
  5. Direction of Rotation
    By BlackCoupe in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-03-2006, 09:01 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
