Re: What Did I Do Wrong - Griot's Pad
Originally Posted by dcjredline
What does the backing plate look like? Is the velcro melted a little in the center too? Definitely looks like heat to me.
Backing plate is great. Only got through the pad face not the second layer or velcro. So I learned a good lesson and will give it another go as soon as my pads arrive. Thanks
You mentioned 12 total passes. Was that per section at one time? If you are doing 12 passes at a time that seems like a lot and would definitely lead to heating. I'd try about 4, then wipe polish and inspect. If results aren't what you want, do another 4, etc. You don't want the polish fully drying out as your going. If I misunderstood your post, disregard.
Hi - it was about 4 per section. I'm guessing from what everyone is saying I overworked the area as it was to large. I'm going to cut the hood into 6 sections with 3 passes each and see if that helps. Fresh pads on the way - thanks for your help. Mark
Sent from my SM-N920V using Tapatalk
Ive melted some velcro in the center of my backing plate before and not noticed anything on the pad face. Weird. Good luck you got some great advice going forward.
Last Post: 07-31-2018, 05:36 PM
By ZL1Mike in forum Ask your detailing questions!
Last Post: 11-07-2017, 02:26 PM
By AbileneAutoWerx in forum Auto Detailing 101
Last Post: 07-27-2015, 02:30 AM
By rotzilla in forum Off-Topic
Last Post: 01-03-2012, 04:38 PM
By oldmodman in forum Ask your detailing questions!
Last Post: 04-14-2010, 09:08 AM
