Griots 6" (GG6) with 5.5" BOSS pads
Can any of you share thoughts on your experience with the BOSS pads on a GG6? I have some on order (3 each of the orange and yellow), but would like to know what you think about these (compared to the regular griots pads or LC flats/thin pro). Thanks.
Re: Griots 6" (GG6) with 5.5" BOSS pads
The BOSS pads work GREAT!
And that's because they are THIN!
Thin is in -Mike Phillips
Here's a word of caution however... because they are thin, they will saturate with product more quickly. Wet foam hold heat better than dry foam. So swap pads OFTEN to prevent wearing out your pad prematurely due to,
- Heat
- Violent oscillation
- Pressure
- Moisture
- Chemicals
Like I day...
More pads are better
Hope that helps...
That combo is what I've switched to...and am glad I did. I still use the 5.5" regular Griots red (foam) pads for spreading wax...mainly because I have them and they work well for that. I have found that the orange BOSS pads do 'load up' a little faster, especially with an AIO. I just have enough of them on hand, and swap often.
Originally Posted by briarpatch
and swap often.
And that is the key.
So when placing an order... get extra pads. By swapping often you'll increase the lifetime use of the pads overall. This is a better value for you money instead of trying to use and abuse a few pads throughout a single detail job.
A good rule of thumb for ANY orbital polisher is
One pad per panel
You can quote me on that.
I use mostly 5.5" boss pads on my GG6, best upgrade I did detailing in a long time.
Last Post: 03-31-2019, 03:08 PM
Last Post: 01-12-2018, 02:56 PM
By JCDetails in forum Product Reviews
Last Post: 09-11-2017, 08:33 PM
By Midnite8 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 06-15-2017, 01:37 PM
By crxman2010 in forum Auto Detailing 101
Last Post: 10-08-2011, 07:13 AM
