Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
Thread: Gg 3"
    Super Member VISITOR's Avatar
    May 2007
    9,730
    Super Member Coopers ST's Avatar
    Nov 2013
    Firestone, CO
    1,268
    Re: Gg 3"
    Can you get that into tighter areas then I could with my GG6 with 3" pads?
    ​1991 BRG Miata
    Brad's Detailed Touch
    https://www.facebook.com/Bradsdetailedtouch1
  3. #13
    Nov 2015
    Arizona
    1,419
    Re: Gg 3"
    Quote Originally Posted by Coopers ST View Post
    Tighter, yes. Much tighter, no. I have both. The size difference isn't what I would consider drastic. You can sort of see in this photo.
    Griot's Garage Polisher Club Kit, griots orbital polisher, dual action polishers
    There is a pic of the undersides just after the videos in post 1:
    http://www.autogeekonline.net/forum/...g-project.html
  4. #14
    Apr 2016
    Jupiter, Fl
    62
    Gg 3"
    X
  5. #15
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Re: Gg 3"
    The only way you will get considerably smaller is an ibird, Griot's small pneumatic DA, or their new pneumatic rotary.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  6. #16
    Oct 2016
    208
    Re: Gg 3"
    Flex PE-8 Kompact with a 1" or 2" backing plate. It is a rotary, though (and the iBrid can be as well, if you use the rignt head), if that makes a difference. It also means that you can use extensions on the PE8 to get into tight spots. Justas a suggestion.
  7. #17
    Nov 2013
    Firestone, CO
    1,268
    Re: Gg 3"
    I would rather not do rotary, they still scare me a bit, and I think a smaller one would, be even worse than a big pad.
    ​1991 BRG Miata
  8. #18
    Oct 2016
    208
    Re: Gg 3"
    I understand being scared of the rotary type polishers, I am the same way. But a 1"-2" pad, if you think about it, cannot be anywhere near the damage potential of a larger pad. The speed of the pad at the outside edge of 6" pad is going to be far higher than the speed at the outside edge of a 1" or 2" pad. THe speed at the outiside edge is the important factor, as this is the point at which maximum cut and heating occurs. The PE-8 using a 1' or 2" pad, at the minimum rptm of 1300 RPM won't generate much, if any, heat. You can ask the guys in the Flex section for their experiences regarding this.
    Because of the edge speed, a big pad will always have more potential for harm/damage.
    The Forensic Detailing channel on Youttube does have a couple of videos where he discussed the PE-8, and shows it being used on bumper covers.
  9. #19
    Nov 2015
    Los Angeles, California
    13,765
    Re: Gg 3"
    Quote Originally Posted by Darcy View Post
    Buy the GG 3in backing plate and the 3in boss pads when they come out later this month hopefully.
    That new 3" HD Backing Plate won't be compatible with the GG3. It's for the GG6.
  10. #20
    Jul 2013
    Apex, NC
    1,283
    Re: Gg 3"
    The problem with using a rotary (Flex PE-8) on panels like bumpers where you normally would like to use a smaller polisher, is that the rotary can get very fatiguing. I still love using a rotary and purple foamed wool for quick correction on bigger stuff like hoods, roofs, trunks and most door panels. As well as getting up close to objects (precision stuff like with a 1" or 2" pad).
  1. Replies: 25
    Last Post: 01-15-2018, 08:22 AM
  2. Review of Son1c's "Capped in America" and "Prototype Black Wax"
    By hardrock2401 in forum Product Reviews
    Last Post: 09-20-2015, 07:11 PM
  3. Replies: 56
    Last Post: 04-11-2014, 09:21 AM
  4. Replies: 9
    Last Post: 12-21-2013, 11:16 AM
  5. Replies: 20
    Last Post: 10-08-2012, 12:59 PM
