Results 1 to 8 of 8
    Oct 2011
    can 3401 with mf pads take out 2500grit sandng marks?
    Hi members anyone manage to take out 2500grit sandng marks? by usng 3401 wth meguiars mf pads? hope to seek advise. Thks
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Re: can 3401 with mf pads take out 2500grit sandng marks?
    Quote Originally Posted by apollofin View Post
    Depending on the compound it shouldn't be any problem. Most compounds will take out 1500 with a foam pad.
    Super Member aim4squirrels's Avatar
    Nov 2013
    DFW Texas
    1,078
    Quote Originally Posted by DaveT435 View Post
    Should work, but if you're doing a large area, or a whole car, a foamed wool pad might be easier to work than MF pads on the flex. If it's just a spot fix, you can probably fight thru it.
    Feb 2011
    Minot, ND
    12,365
    When the 3401 is equipped with a fiber pad (mf pad, wool pad, etc) and quality compound it will surely pull out 2500 sanding marks without any issue.
    I've pulled out more aggressive sanding marks than that without issue. I find wool pads such as the Hybrid wool pads behave much better on the 3401.
    Super Member refreshauto's Avatar
    Feb 2014
    Odessa, TX
    1,158
    Get a flash pad from Carpro, you will get great results
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    You should be good. I just buffed 2000 grit aftermarket paint with m105 and a blue rupes microfiber pad on a PC.
    I did 1000 grit on a scrap Honda door over the winter. That paint was a bit softer than what I worked on today.
    Feb 2014
    Odessa, TX
    1,158
    Took these deep scratches out of this hard Mercedes with the 3401 a flash pad and flat top with ease.
    Attached Thumbnails Attached Thumbnails can 3401 with mf pads take out 2500grit sandng marks?-1441658449162-jpg
    It should work just fine. At least on flat panels that are easy to buff.
    Any tool/pad/compound combination that can remove paint will remove sanding marks it's just a matter of how much time you want to invest into the project.
    The fastest approach would be a rotary buffer with a wool pad and a compound. Every other approach will work... sooner or later... just the time factory.
    What are you working on?
    Are you hand sanding or machine sanding?
    My guess is hand sanding as I don't know of any company that makes sanding discs in #2500 grit.
  1. Lambswool pads for removing sanding marks w/ rotary
    By mwoywod in forum Auto Detailing 101
    Last Post: 03-01-2017, 08:44 AM
  2. Flex 3401 + Hydro Pads or GG + MFDA PADS
    By fredcandetail in forum Auto Detailing 101
    Last Post: 05-20-2011, 09:41 AM
  3. Pads Leaving Swirl Marks
    By AndrewBall in forum Wet-Sanding, Cutting & Buffing
    Last Post: 10-25-2010, 01:05 PM
  4. Can you remove sanding marks with the Flex 3401
    By Shane731 in forum Ask your detailing questions!
    Last Post: 10-19-2010, 08:25 AM
  5. 3401 . . . what pads are you using?
    By WHEC716 in forum Flex Polishers
    Last Post: 10-26-2009, 10:59 AM
