Results 1 to 7 of 7
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Flex 3401 Pad Questions
    Hi Everyone
    1. Which LC pads cut more, 5" Orange LC Hybrid with 4" LC BP or 5.5" LC Yellow Flat with Flex 4 3/8" BP?
    2. Flex 3401 being DA and Direct Driven, do larger pads cut more like a rotary or smaller pads cut more like a DA?
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,027
    Re: Flex 3401 Pad Questions
    I believe the Orange Hybrid is the heaviest cutter, according to the charts.
    Aug 2013
    Tustin, CA
    4,389
    The Flex 3401 is a beast!!
    IMO the Hybrid Pads from Lake Country are the way to go. I believe the Pads were designed for the Flex 3401. The Orange Pad is the heavier cut for the Hybrids. I cannot comment on the LC Yellow Flats as I have never used them as I had excellent results from the Orange Hybrid Pads whether it be the 5" or 6.5" Pads.
    I use the 6.5" Pad more than the 5" Pads. However, the 5" Pads give you better control and more of a "finesse" pad. The 6.5" Pads cover more area.
    The Flex 3401 is the closest machine to be a rotary. The forced rotational oscillation is 2nd to none. It can work on curved panels and can tackle any correcting needed when compounding/polishing. I also use it to apply sealant/wax too.
    Bottom line the Hybrids are the way to go Orange, White, Black, Red or Gold Pads.
    CJ
    Save the Manual!
    Super Member MIsnowman's Avatar
    Jun 2015
    332
    I would think the 5" orange hybrid would cut more than the 5.5" yellow because it is a more agressive pad, the difference in diameter is negligible IMO. If you were comparing a 5" to a 7" then there would be a difference, but I don't think 1/2" will matter. Also, I would treat the Flex more as a rotary than a D/A in terms of the way it handles pad size. Smaller thinner pads work better on traditional D/A's because the pad rotation speed is higher with the smaller pads. The flex will turn the same speed no matter what size pad you're running.
    Feb 2011
    Minot, ND
    12,365
    The Orange Hybrid pad is the most aggressive foam pad offered by LC.
    Lake Country Hybrid Aggressiveness Pad Chart
    Lake Country All Wool & Foam Comparison Chart
    In time out
    Sep 2014
    1,631
    Thanks guys, so it seems that and just to clarify, from all LC foam pads the Orange Hybrid is the most aggressive and the 6.5" Hybrid will have more correcting power over the 5" Hybrid as the direct driven machine will not slow down at all.
    In time out
    Sep 2014
    1,631
    Quote Originally Posted by Mike@DedicatedPerfection View Post
    Wow! You have truly cleared all my LC pad confusion in one simple post and saved me tons of cash! I've bookmarked these links in my own personal detailing treasure chest. You are a star!
  1. Flex 3401 questions
    By jafo1219 in forum Ask your detailing questions!
    Last Post: 06-01-2015, 06:10 PM
  2. Replies: 9
    Last Post: 10-17-2013, 05:20 AM
  3. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  4. Questions about pads and the flex 3401
    By touringsedan in forum Auto Detailing Tools and Accessories
    Last Post: 05-06-2012, 10:08 PM
  5. Few Flex 3401 Questions/Comments
    By Wills.WindowsAndWheels in forum Auto Detailing 101
    Last Post: 07-02-2011, 02:26 PM
