First day with 3401 impressions
I posted awhile back about decided between the 3401 and the pe14 150. I ended up going with the 3401, just received it in the mail today.
I work on two and a half cars today, thought I would quickly share my first impressions.
I have been using the Makita, and before this I used the Dewalt quite a bit. I've also used the Porter Cable random orbit.
First things first, the 3401 is very light compared to the rotary polishers. You can also sense the build quality when you pick it up.
I found the handle that comes with it isn't great, I took it off after the first hour or so. To stick with the positives first, the 3401 works extremely well. With only a few passed with product I'm very familiar with I was getting much faster and clearer results. I think the smaller 6" pads allow a bit more control than the standard 7-8" pads, and the movement of the 3401 insures you aren't leaving buffer trails. The weight also makes it more manageable which in turn produces better results I think.
When it comes to the controls and ergonomics I was less impressed. You can't see what speed setting you're at without turning the machine over, I've found this to be really annoying. Maybe it will be less of an issue once I recognize the sounds of the machine better. I can't seem to find a comfortable way to hold it either, with or without the handle. Compared to the Makita, the vibration is VERY strong. I'm used to a heavy machine, but I felt like the 3401 was trying to wiggle its way out of my hands from time to time. I remember this with my Porter Cable as well, but as the 3401 has more power, it feels a bit worse. So I can't say it was an enjoyable machine to use, but the results were definitely superior. This is only day one, so I will check back again at the end of the week. I'm looking to replace my personal polisher at home as well, I think I may end up with the pe14 150 for personal use. If I find any interesting cars to do, I will post photos as well.
Re: First day with 3401 impressions
did you use the bale handle or the side handle?
I use a side handle... helps a bunch.
FLEX Polisher Side Handle
Also you will get use to the speed settings and won't need to look if you use it often enough.
Give it a couple weeks or a month and you will handle it no problem.
It only came with the bale handle. I imagine the side would be more comfortable. We'll see how it progresses! I am happy with the results, just some adjustment time needed I hope.
I also think my expectations were pretty high!
I remember the other thread you started. I recommended the 3401 too. I'm with you on the ergonomics. I don't like how you have to hold it. It's awkward and different. I'm getting blisters on my hand at around the base of my thumb. Germans must have big hands lol. If you think the 3401 is light you should try the Flex rotary.
i been using my 3401 about 5 times a week for the past several months. now i couldnt live without it. i really like the bale handle, fits me and my style perfectly. i also dont use a handle on my dewalt, i feel i have more of a soft touch.
Sent from my QMV7B using AG Online
Originally Posted by Corey@OptimalDetailing
What pads are you using?
This is a excellent question. I used mine all day today on a jet black '08 Lincoln Town Car. The pads you use make a big difference on how smooth the 3401 runs. Used, orange, white and blue CCS 5 1/2" pads and it ran as smooth as silk. Put on a new Rupes blue 6 1/2" cutting pad, just to try it, and the machine vibrated so bad I took it off in a couple of minutes. I didn't try the softer Rupes pads so I can't comment on them. Should have known better than to order pads made specially for another machine but that's my fault, not the machine.
I think the 5 1/2" pads are the best over all including the Hydro-Tech pads. I want to try the Hybrid pads but haven't ordered any yet.
Don't worry, when you get used to running it you will like it.
I'm currently using the LC Hydrotech. They are nice pads, I think I prefer the CCS though. I'm definitely going to try the rotary, I used one of the original flex rotaries and really liked it, I imagine its only gotten better. Will post again at the end of the day I guess!
Congrats on the 3401!
If you have a chance, order some of the Hybrid pads to try out. These work extremely well with the characteristics of the 3401.
If you need to replace one of your other rotary machines, the PE14 is a top notch unit.
By Trevine in forum Auto Detailing 101
Last Post: 04-07-2019, 06:09 PM
By TTQ B4U in forum RUPES BigFoot Oribital Polishers
Last Post: 06-18-2018, 05:36 AM
By Jeremy1976 in forum Flex Polishers
Last Post: 06-10-2016, 10:16 PM
Last Post: 11-18-2011, 08:06 PM
By littlemissGTO in forum Auto Detailing 101
Last Post: 11-17-2007, 09:36 PM
