Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
    Feb 2011
    Minot, ND
    12,365
    A FLEX comparision: PE14 vs 3401
    Well Geeks I had a bit of time the other day to bring along my pair of FLEX’s for a side by side comparison. I wanted to see how these two machines would operate and handle next to each other as well as check the level of correction each one had to offer. For this test comparison everything was kept identical with the only variance being the tool itself.
    The darkest vehicle I could get my hands on was a dark blue metallic Chevrolet van. I cleaned up the test panel and taped it off for some side by side work. The left side was done completely with the PE14 and the right side only the 3401. The correction and polishing step was exactly the same. For correction I used an orange 6.5” Hybrid pad, FG400, and speed 3. For polishing work I used the 6.5” white Hybrid pad, SF4000, and speed 5. Again both sections received the exact same treatment with the only difference being the tool itself. The “Smack Technique” was utilized on both machines.
    As for the performance between the two machines side by side utilizing the same products, they were quite similar in that both did a tremendous job at removing the swirls in the paint with the PE14 achieving 10% more correction due to it being a rotary. Both machines finished down extremely well with no discernible difference on this hard GM paint.
    As for correction times I did not keep official track of them with a clock. I kept everything the same and the 3401 had no problems keeping up the PE14 due to its forced rotation nature. Both sections were completed in roughly the same time.
    When both sections were completed they each received an Eraser wipe down and when I pulled the tape off the entire section received another Eraser wipe down. My LSP of choice was Pinnacle Synergy applied by hand to top off my efforts. All pictures were shot with my Nikon D3200, standard 18-55mm lens with hood, and my Nikon SB-700 speed light with diffuser were the flash was used.
    For some more reading on the “Smack Technique”
    http://www.autogeekonline.net/forum/auto-detailing-university/77155-my-technique-concerning-3401-menzerna-products-hybrid-pads.html
    http://www.autogeekonline.net/forum/auto-detailing-university/80973-utilizing-smack-technique-pe14.html
    The van used for the test.
    The panel being used
    Taped off ready for the comparision
    First up, PE14 on the left
    And the 3401 on the right
    Next up is the polishing step.
    Now to check my results
    Feb 2011
    Minot, ND
    12,365
    Re: A FLEX comparision: PE14 vs 3401
    Feb 2011
    Minot, ND
    12,365
    And all the afters
    Feb 2011
    Minot, ND
    12,365
    I hope you guys enjoyed this write up and undertaking as well as I did. I will be happy to answer any questions you may have.
    Mike
    Junior Member Denis Ware's Avatar
    Jun 2012
    Long island, New York
    58
    Great Job. This is what l was looking for in review in both machines because l have the Flex Pe-14 I think works outstanding (good review)
    Super Member HUMP DIESEL's Avatar
    Dec 2013
    Gaffney, SC
    930
    Proof positive that a rotary when used correctly can achieve tremendous results. The Menz products don't hurt the equation either.
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Thank you, smack. Outstanding comparison and display of both machines.
    Feb 2011
    Minot, ND
    12,365
    Quote Originally Posted by Denis Ware View Post
    Thank you sir!
    Glad you enjoyed the read.
    Quote Originally Posted by HUMP DIESEL View Post
    Thanks for the kind compliments Diesel!
    Quote Originally Posted by Puckman View Post
    Thank you sir!
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    Nice comparison Mike and great pictures. Did you use speed 3 on the PE14 & 3401 for the correction step? Did you also use speed 5 on the PE14 for the polishing step or did you keep it a speed 3?
  10. #10
    Feb 2011
    Minot, ND
    12,365
    Quote Originally Posted by FrankS View Post
    Thanks Frank!
    Everything was performed exactly the same on both machines. Speed 3 for correction and speed 5 for polishing.
  1. DVD - How To Use the Flex 3401 & PE14 Rotary Buffer
    Last Post: 01-21-2015, 12:08 AM
  2. FLEX 3401 or PE14-2
    By NY-Bondo in forum Auto Detailing 101
    Last Post: 05-24-2013, 05:56 PM
  3. Time to step it up, PE14-2 or 3401?
    By veeko in forum Ask your detailing questions!
    Last Post: 11-16-2012, 02:22 AM
  4. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  5. PE14-2 or 3401
    By SDS97_7.3 in forum Flex Polishers
    Last Post: 06-17-2011, 11:29 AM
